Pocket GPS World :: View topic - How do i add poi?
How do i add poi?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator
keith405
PostPosted: Tue Jun 20, 2006 6:47 pm    Post subject: How do i add poi? Reply with quote
I have an Acer n35 with destinator pn i am tring to find out where i can download poi for Banks then how do i get the poi into my Acer.
Thanks for any info
Keith
gahodgkinson
PostPosted: Fri Jun 30, 2006 9:32 pm    Post subject: Re: How do i add poi? Reply with quote
Thanks for any info
Keith
I am using a mio 168 digiwalker & I found that I was able to import & convert a csv file containing a listing of National Trust properties into favourites using the destinator console. Works quite well but as to getting them in as poi still not worked that one out just yet.
Can route to them & see them on screen as icons. It may be a temp answer to your problem.
keith405
PostPosted: Sat Jul 01, 2006 12:48 pm    Post subject: Reply with quote
Thanks gahod that's what i have done put them in my favourites do you know how i can put voice files in for ech fav place ie speed camera's banks etc instead of my favourites for everything.
TT 920
Acer N35 & Destinator PN
Paul80
PostPosted: Tue Jul 04, 2006 11:48 pm    Post subject: Reply with quote
Give the following a try
Select your voice file
Re-name the file to match your csv file
ie Gatso.csv then you need Gatso.wav or Gatso.spx if your version uses spx files although IIRC PN used wav files
Copy your wav/spx file to the voices\all folder
If you also want to use a custom Icon for display on the map this also has to be named the same as the other files ie Gatso.bmp and this is put in the Favorites folder.
Hope this has helped.
allmen
PostPosted: Thu Jul 06, 2006 12:52 am    Post subject: Reply with quote
I can get the POI to load but I would like to know how to get the speed cameras audio warning to work. I tried to do the same as with the Dest 3 voice.inf file but it will not work nor will the visual. Is the set up different for the two systems.
allmen
PostPosted: Thu Jul 06, 2006 12:53 am    Post subject: Reply with quote
Re the above post by the two systems I mean Destinator 3 and Destinator PN.
Acer N35
Destinator 3
Destinator 6
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator All times are GMT + 1 Hour
