anson Occasional Visitor
Joined: 01/08/2003 02:33:05 Posts: 5 Location: Australia
Posted: Sun Sep 14, 2003 8:04 am Post subject: Haicom 303MMF NMEA Commands??? |
Thanks for your help David. I have the software tools to enable the VTG string so I will just have to do it that way.
Thanks Again
Anson |
I have recently received a Haicom HI-303MMF GPS Receiver and noticed that the Factory Settings for the NMEA strings that are output does not include the VTG string. I am developing an application in Embedded Visual C++ and using serial communications to recieve the GPS NMEA data. I need the VTG string however and am not sure of the commands that can be used to enable it.
If someone could please help me by providing these commands or a link to where they can be found I would be very appreciative. So far the Haicom manual has proven to be a waste of time regarding this issue.
Thanks in Advance
Anson |
DavidW Pocket GPS Moderator
Use standard SiRF configuration tools like WinFast Navigator. The Pocket PC configuration application included on the CD-ROM allows you to make some changes, but it doesn't give you that fine a control over NMEA sentences output.
You have to be using the HI-303MMF in CompactFlash mode for any configuration to work - in mouse mode there's no serial input.
This article shows the use of WinFast Navigator on the Pocket PC - the Commands -> NMEA screen allows you to choose the NMEA sentences output and the period of time (in seconds) between outputs.
David |
Hey David,
Thanks for the input but I have already tried the WinFast Navigator. It works fine but I'd really like to be able to enable the NMEA VTG string from a Serial port connection if possible. The potential users of the application will not know how to configure the NMEA output so I would like my application to make sure it is enabled even though the likleyhood that the setting will be changed is very minute.
Any ideas would be greatly appreciated.
Anson |
In that case, you will have to modify the hardware. As it stands, there is no data input when using a serial cable. My understanding is that this is to prevent damage to the hardware, as there's no way of disconnecting the CompactFlash UART from the GPS chipset's serial input when a cable is inserted.
If you don't intend to use the CompactFlash port, I suggest you buy a SiRF II based GPS mouse such as a Leadtek 9532, which does have a serial input via a cable. It's also cheaper than a HI-303MMF.
David (going from what I understand here, not from first hand knowledge - I'm not prepared to break the warranty seal on my HI-303MMF) |
Interestingly, a look at the Haicom site today shows the HI-303E. It looks identical to the HI-303MMF (colour and model number excepted), and the manual rubbishes my initial thought that it was a HI-303MMF without the mouse mode option.
I wonder if this is a HI-303MMF with a serial input in mouse mode - but that is only a guess. At the moment, I have no idea what the differences between the two models are.
David |
