lee_car Occasional Visitor
Posted: Fri Jan 27, 2006 4:35 pm Post subject: TomTom 5 Question |
hi i have a HP 2110 pda and it wont sync with my pc, a common fault i believe, if i buy a original tomtom 5 software will i be able to install it with the sd card and activate it with the code with out needing a pc?
and where is cheapest to buy the software?
cheers lee |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Fri Jan 27, 2006 5:35 pm Post subject: Re: TomTom 5 Question |
lee_car wrote: | hi i have a HP 2110 pda and it wont sync with my pc, a common fault i believe, if i buy a original tomtom 5 software will i be able to install it with the sd card and activate it with the code with out needing a pc?
Yes, if you have a card reader you can copy the .cab files (these are just like .zip files) from the install CD's onto the SD card and run them manually from there. |
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Fri Jan 27, 2006 5:38 pm Post subject: |
Hi lee_car,
to the forum!
lee_car wrote: | i have a HP 2110 pda and it wont sync with my pc, a common fault i believe |
Has it ever synchronised with your PC?
Have you tried temporarily changing the 2110’s device name? Let us know if that works and I’ll dig out a link to reset the PC side of things so that you can use the original device name again.
lee_car wrote: | if i buy a original tomtom 5 software will i be able to install it with the sd card and activate it with the code with out needing a pc? |
Yes, dropping an original TomTom SD card into your PDA will auto install TomTom Navigator. If you do need to active it, you don’t need the PDA to be connected to the PC.
However I would try and get your 2110 to synchronise with you PC, it’s a lot easier to add custom POIs. However a card reader is a useful thing to have as well! ;)
lee_car wrote: | and where is cheapest to buy the software? |
Check our advertisers on the right hand side of the screen.
Garmin Camper 770 LMT-D |
Posted: Fri Jan 27, 2006 5:55 pm Post subject: |
cheers ill buy it then, i have a card reader, i might just buy a new pda as well in the future
it did sync but then stopped, i have tried hard reset and soft reset, i have also tried 4 different comps and still not on any, but i found this http://www.ipaqrepair.co.uk/view_product.php?product=308
so i think it might be this problem
cheers lee |
Posted: Fri Jan 27, 2006 5:56 pm Post subject: |
oh i already have tomtom 5 but i have no code for it, can you buy just the code?
cheers lee |
Posted: Fri Jan 27, 2006 6:14 pm Post subject: |
cheers ill give it a try, ill let you know how i get on
bloody ebay, i thought i was bidding for a complete tomtom 5 and wired receiver but it wasnt
cheers lee |
Posted: Fri Jan 27, 2006 6:25 pm Post subject: |
oh its the 2210 not the 2110
cheers lee |
andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1039 Location: East Sussex
Posted: Fri Jan 27, 2006 6:34 pm Post subject: |
i think you might have deleted 1 of the items in notification queue ,i had this problem once before with a 2210.... have you had a look use pocket mechanic if you can get it _________________ TomTom 5001 |
Posted: Fri Jan 27, 2006 6:37 pm Post subject: |
how do i get into registery files?
i tried the second part but there is no file application data after my username
when i try connecting with mine it says
YOUR DEVICE WAS NOT DETECTED
DRIVE:\Documents and Settings\USERNAME\Application Data\Microsoft\ActiveSync\Profiles and delete the profile there.
cheers lee |
Posted: Fri Jan 27, 2006 6:39 pm Post subject: |
andy-c1 wrote: | i think you might have deleted 1 of the items in notification queue ,i had this problem once before with a 2210.... have you had a look use pocket mechanic if you can get it |
where would i get that?
thanks lee |
peterc10 Frequent Visitor
Posted: Sat Jan 28, 2006 10:26 pm Post subject: |
lee_car wrote: | oh i already have tomtom 5 but i have no code for it, can you buy just the code?
cheers lee |
Yes you can buy the code. It even comes with a free legitimate copy of the software. _________________ Peter
HTC Sensation
Copilot for USA
Posted: Sun Jan 29, 2006 4:16 pm Post subject: |
peterc10 wrote: | lee_car wrote: | oh i already have tomtom 5 but i have no code for it, can you buy just the code?
cheers lee |
Yes you can buy the code. It even comes with a free legitimate copy of the software. |
oh so the softwares free?? doesnt really matter if its a copy then if its free anyway, pretty expensive code tho, where can i buy such a code then?
if youve got nothing constructive to say please dont post
lee |
