sybaseian Occasional Visitor
Posted: Thu Jun 23, 2005 3:18 am Post subject: TT5 crashes when navigating or planning route |
I've just upgraded to TT5 from TT3 on a XDAIIi with a syson BT (which works after the reg hack). The problem I have is when I try to demo a planed route or to navigate from home to another location, TT5 shuts down completely and I have to reboot. Even if I try again, it immediately shutsdown.
I'm currently running the o2 Active non-corporate software and have tried it on and off.
Flight mode on and off.
Nothing seems to stop it from shutting down.
Any ideas what may be causing it to shutdown?
I've removed all the POIs and have disabled them as well.
XDAIIi
512Mb Kingston Ultimate 133x SD |
vishaljh Occasional Visitor
Posted: Thu Jun 23, 2005 9:37 am Post subject: |
I had the same problem. And the only way i could stop TomTom from exiting mid-way through the route is using POI.Dat from tomtom 3.
Cheers,
Vishal |
Posted: Thu Jun 23, 2005 9:42 am Post subject: |
Cheers,
Vishal |
Posted: Thu Jun 23, 2005 9:43 am Post subject: |
I've changed the orig POI and swapped it for the TT3 POI, but it still shutsdown.....
Cheers |
Posted: Thu Jun 23, 2005 12:07 pm Post subject: |
I've now swapped back to the original TT5 POI and it has stopped crashing and lets me plan and demo a route.
However, I now have another problem - it's missing the default POIs.
You'd think that TT would employ some more software testers before releasing the next version....... |
alix776 Pocket GPS Moderator
Posted: Thu Jun 23, 2005 8:01 pm Post subject: |
it runs fine on my xda2i what reg hack to get the bt working ive never needed to do one _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Thu Jun 23, 2005 9:49 pm Post subject: |
alix776 wrote: | it runs fine on my xda2i what reg hack to get the bt working ive never needed to do one |
Quote: | Open your registry editor on your PPC.
Browse to: HKEY_LOCAL_MACHINE\Software\Widcomm\AutoConnect\000x ("x"
is the number of the com port your GPS operates on, mine is on Com7 so
I navigate to "0007").
Locate the key "BtBrowserEnabled" and change it from "1" to "0".
Load up TomTom and go into the preferences and re-setup your GPS
Receiver selecting other Bluetooth. It should work now... |
