Pocket GPS World :: View topic - Garmin Etrex accuracy
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers
Melismobile
PostPosted: Fri Apr 15, 2005 12:22 pm    Post subject: Garmin Etrex accuracy Reply with quote
I bought this unit primarily to locate specific points eg rocks with fish under them. But I find it is not really accurate enough. Is there a patch that will increase its accuracy ?
Mel
missing_user
PostPosted: Fri Apr 15, 2005 1:49 pm    Post subject: Reply with quote
I have two Garmin units,eMap and iQue, and the best accuracy I have noted is 16 feet in the UK!
What accuracy are you getting, and what accuracy are you expecting?
Melismobile
PostPosted: Fri Apr 15, 2005 2:22 pm    Post subject: Reply with quote
Well 16 sq foot is an aweful lot of rocks on a beach 8O I guess minimum 1m square would be nice
Mel
missing_user
PostPosted: Fri Apr 15, 2005 2:32 pm    Post subject: Reply with quote
Only the Military people have that accuracy as far as I know.
Melismobile
PostPosted: Fri Apr 15, 2005 2:55 pm    Post subject: Reply with quote
I was told it was possible to get a better accuracy Oh well waste of space then Sad
Mel
missing_user
PostPosted: Fri Apr 15, 2005 3:03 pm    Post subject: Reply with quote
Just been told by a friend that Surveying Organisations/Local Government Planning may have equipment more accurate for your work!
Skippy
PostPosted: Fri Apr 15, 2005 3:04 pm    Post subject: Re: Garmin Etrex accuracy Reply with quote
A couple of things to try:
Switch on WAAS which will give you a more accurate fix if you can see the WAAS satellite. You will know if you do because you will see the letter "D" appear in the GPS status screen and it will say "3D Differential Fix". This is supposed to improve the accuracy to better than 3 meters.
Some Garmins also have an "averaging" feature. Your position acutally jumps around a bit even when you are standing still. On my GPS-V you can mark a waypoint as an average location measured over a minute or two which may give a more accurate reading.
If you mark a waypoint and then come back to it within a few hours, then you will probably get a fairly accurate pointer back to where you were. If you come back days later then you may find that the waypoint has shifted a fair bit.
You can get very accurate survey grade GPS systems (sub centimeter) but these are quite expensive, bulky and cumbersome to use.
The bottom line is that, in the real world, it doesn't really get a whole lot better than what you already have. Crying or Very sad
Gone fishing!
Melismobile
PostPosted: Fri Apr 15, 2005 7:43 pm    Post subject: Reply with quote
Thanks I'll try the suggestions. Taking more equipment (ie biger survay stuff) is not really a viable option, as there are other things I have to carry as well Sad
Yes I return days later, as I'm studying homing behaviour and trying a non invasive methodology. I was hoping to lessen the marks on the rocks if I could get the GPS more accurate.
Mel
oddsock
PostPosted: Fri Apr 15, 2005 10:19 pm    Post subject: Reply with quote
Mel
Idea Would digital photo's be out of the question Maybe you could take one of the rock from your waypoint and then when you go back to the spot you could refer to the print/review screen to make the ID !
Melismobile
PostPosted: Fri Apr 15, 2005 11:45 pm    Post subject: Reply with quote
Yes I do that too. And photos of the rocks lined up with a fixed point or 3, eg lighthouse, visible house, which won't move (I hope)
It helps if you get within a metre or two, but not much further away which is where I hoped the GPS would come in. Lost a total of 4 rocks last survay, which wasn't too bad, but it is frustrating Sad
It is surprising how different a rock can look from a slightly different angle, 2D to 3D fails quite a bit. So I'm not sure how many photos I'd need to make a really good ID if I approched it slightly incorrectly ;)
I'm using digital photos as fish identification rather than physically marking them, which has been great.
Mel
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers All times are GMT + 1 Hour
22.054 (22 May 24)
