iowmg Occasional Visitor
Posted: Mon Apr 05, 2004 3:54 pm Post subject: honda crv jap import sat nav |
is there any way to change the language from japanese to english
i have bought the uk maps dvd and it seems to be tracking but as you can imagine you cant understand it if your not fluent in japanese ![Confused](modules/Forums/images/smiles/icon_confused.gif) |
![](modules/Forums/images/avatars/32928398450ec149ec6abd.gif)
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Mon Apr 05, 2004 4:17 pm Post subject: |
I don’t know. The best bet is to determine the make of your inbuilt SatNav system, and either ask the UK head office (I have to assume that you’re based in the UK) that question or a local dealer/fitter of the SatNav system.
Alternatively you could ask your local main Honda dealership for help, but as your vehicle is an import then they may either refuse to help or charge you the earth for the fix . Alternatively, if you have the vehicle serviced by an independent garage or one that specialises in Jap imports then they may be able to help you.
Final suggestion is to try the web for a UK CRV club, as their members may have already come across this problem.
Sorry I can’t be of any more help. I wish you well in your quest.
Garmin Camper 770 LMT-D |
lgh2k Occasional Visitor
Posted: Thu Jun 24, 2004 7:04 pm Post subject: honda crv at nav system |
hello mate - did you have any luck with your import? I have just bought the same car & am experiencing the same problems!
cheers
Lee Harrison
lgh2k@ukonline.co.uk |
nikaves Occasional Visitor
Joined: 28/07/2003 15:53:30 Posts: 7 Location: United Kingdom
Posted: Tue Mar 01, 2005 12:07 am Post subject: |
Make sure you have the security code before trying the following.
First, try disconnecting the car battery and then re-connecting it after say 20 seconds. Power on the Sat Nav and it will hopefully have reset itself. After entering the 5 digit security number, it will then ask you what language you want to put it in!
If disconnecting the car battery does not reset the SatNav, you'll have to remove the unit, unplug all the cables at the back, reconnect, and then do the above. To remove the unit, there are 2 cross head scews below the unit (pointing upwards), remove these. Pull the facia out from the bottom slightly, and then pull the top.... it clips in at the top.
This will reveal 4 screws holding the main unit in. Remove these and the unit should slide out forwards.
Good luck!!! |
