Pocket GPS World :: View topic - North West postcodes ttg
nich
PostPosted: Sun Feb 06, 2005 11:14 pm    Post subject: North West postcodes ttg Reply with quote
I have just installed the nw postcodes but can only find WA addresses. Last time i looked the nw was a little bigger than just Warrington. Any ideas what iv done wrong.
cheers
sgould
PostPosted: Sun Feb 06, 2005 11:40 pm    Post subject: Reply with quote
What size SD card have you got? The 128Mb supplied in the UK may not have enough room on it. The 5Mb .ov2 may be too much.
nich
PostPosted: Mon Feb 07, 2005 10:39 pm    Post subject: Reply with quote
Hi iv got a 512mb card with GB & French maps and speed camera info only.
nich
Oldboy
PostPosted: Tue Feb 08, 2005 12:15 am    Post subject: Reply with quote
It may seem a daft question but how many WA codes can you see?
The TTG will by default will show you only the nearest few by default.
If you enable the POI you should be able to see them all on the map display. If you can't, there must have been only a partial loading of the POI file - very strange. In the original there are quite a few different codes.
sgould
PostPosted: Tue Feb 08, 2005 9:12 pm    Post subject: Reply with quote
Try searching for some that you can't see on the screen. As stated it will only show the ones nearest you.
When typing in the postcode, don't forget the space and ignore any "PoI not found" messages until you have typed the whole code in.
sgould
PostPosted: Tue Feb 08, 2005 9:14 pm    Post subject: Reply with quote
Oh! and wait while it searches. It can take a very long time.
nich
PostPosted: Tue Feb 08, 2005 10:49 pm    Post subject: Reply with quote
I only seem to have the WA15 postcodes ( My own is WA15).
I think im doing something wrong.
Could someone please give me a step by step guide to using the postcodes as a poi. The NW codes are installed, but what next. How do i find an address by poi.
fin
PostPosted: Tue Feb 08, 2005 11:01 pm    Post subject: Reply with quote
yes i would like to no aswell
Oldboy
PostPosted: Wed Feb 09, 2005 9:24 am    Post subject: Reply with quote
The 1st way to use the Post Codes is to go -
Navigate to... / Points of interest / Post Code / tap 'Keyboard' / type in full Post Code including space.
There will be a pause while TTG searches the file - I've never found it longer than 30 secs.
TTG will then display the Post Code, with the distance 'as the crow flies'. Do crows fly in straight lines?
OR
TTG will display No POI found!
The 2nd way is to use Browse Map -
go to Browse Map / Find (the mag glass at bottom) / Points of interest / Post Code / tap 'Keyboard' / type in full Post Code including space.
Once again you have to wait for the message, as above. Then the browse map will display the location of the Post Code if it finds it. The only difference is that it displays, on the map, all of the Post Codes in that file!! If you don't need them displayed all the time you will have to deselect them in the options.
If you still can't find what you want - go to 'Maintain POI' in Change Preferences and set the 'Post Codes NW' to display. If you then Browse Map again you should see loads of icons all over the NW area.
If you don't you will probably have to reload the file from your PC, as it would appear to be incomplete.
Good luck
Tap the blue 'quadrant button' and choose Navigate to ...
nich
PostPosted: Wed Feb 09, 2005 7:51 pm    Post subject: Reply with quote
Thanks for the details Richard. I have know found some other postcodes as far as Crewe. Another Question.
Is Liverpool and Cheshire Oaks class as the North West, if so i cant find them. can anyone define the bounderies for me of the NW.
Thanks again
Oldboy
PostPosted: Wed Feb 09, 2005 7:57 pm    Post subject: Reply with quote
I appear to have had a bad moment there!!
This line should follow -
and be before -
Glad you found that the NW is a little larger now!!
Oldboy
PostPosted: Wed Feb 09, 2005 8:17 pm    Post subject: Reply with quote
nich wrote:
Another Question.
You should find 15 Post Codes in NW file.
They are:
BB-BL-CA-CH-CW-FY-L-LA-M-OL-PR-SK-TF-WA-WN
Does that help?
nich
PostPosted: Wed Feb 09, 2005 11:26 pm    Post subject: Reply with quote
Thanks Oldboy (sounds grand that does)
Yes i have all those postcodes.
It does help when you know what your doing.
Thanks to all involved.
PS thanks to the parties who listed the sounds for the speed cameras. TOP NOTCH.
boris
PostPosted: Thu Feb 24, 2005 12:31 am    Post subject: Reply with quote
Just like to say thanks to Richard for the info given on searching POI's. I was just scrolling down the screen and thought the postcodes were incomplete as I couldn't find the ones I wanted. Use the keyboard option - which I handed sussed works 200 times better. Thanks again great forum!
Boris Embarassed
OR
Good luck
22.062 (12 Jun 24)
