tbfisk Occasional Visitor
Posted: Thu Jan 06, 2005 10:07 pm Post subject: Help! Toshiba e750/Earthmate with USB<->Ser cable |
I have the DeLorme Earthmate running (err...well…sometimes…) with a USB<->Serial cable on a Toshiba e750 with the Prolific PL-2303 driver. The problem that I have is that about 95% of the time, when connecting the USB<->Serial cable to the e750 the error message
USB OVER CURRECT DECTECT
USB device is turned off. Please
Disconnect USB device.
I have tried everything I know of to try to figure out why this is coming up…from soft reboots to a total device reset. Usually I can get everything working after a total device reset…but only for a while. If a soft reboot is done, then most likely I will end up with the error message again.
Have you heard of this? Any ideas?
Thanks!
Tom |
lbendlin Pocket GPS Staff
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Fri Jan 07, 2005 12:00 am Post subject: |
I think the message says Over-Current. Get a GPS receiver that consumes less power. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Fri Jan 07, 2005 12:34 am Post subject: |
Yes...a typo on my part. Over Current. I am using a powered USB<->Serial cable from Supply.Net (http://www.thesupplynet.com/searchresults.cfm?mySearch=product&prodName=210) that supposedly powers the GPS device rather than the e750.
So you are saying that the GPS is not getting enough power? |
Posted: Fri Jan 07, 2005 12:47 am Post subject: |
yes, the GPS (and the USB>Serial converter) draw more current than the Toshiba can deliver _________________ Lutz
Pc-Mobile Frequent Visitor
![](https://www.pocketgpsworld.com/blank.gif)
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Fri Jan 07, 2005 4:16 pm Post subject: |
tbfisk wrote: | Yes...a typo on my part. Over Current. I am using a powered USB<->Serial cable from Supply.Net (http://www.thesupplynet.com/searchresults.cfm?mySearch=product&prodName=210) that supposedly powers the GPS device rather than the e750.
The cable should power BOTH the PDA and GPS.
The over-current message may pop up occasionally in this set up (USB>serial converter).
Does it come up with or without external power (from cigar lighter)?
If it comes up consistantly with external power connected, you may have a defective cable. _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
