spacerace Occasional Visitor
Posted: Thu Nov 11, 2004 10:26 pm Post subject: POI Only Visible When Stationary |
Not sure if anyone else has experienced this, I've been searching but found nothing.
I installed CoPilot from the quickstart Mini-SD card and all worked fine. I then decided to add in the Speed Camera database to the inbuilt POI list.
I followed the instructions for importing and then downloaded all the data to the Mini-SD card afresh and re-installed.
Now the problem is that all POI (existing and new speed cameras) are only visible when stationary. When I am moving they all disappear ! I can temporarily fix this by switching views which shows all the POIs on the new view up until the point where I come to a stop. As soon as I move again they all disappear again.
Anyone any idea what might be causing this ? I have all POI settings switched on in Options, and have uninstalled and re-installed twice now.
I can't remember if it ever worked ok but I guess it must be something I broke upon updating the installation. _________________ - spacerace - |
Skippy Pocket GPS Verifier
![](modules/Forums/images/avatars/7197988194d2507f52befb.jpg)
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Thu Nov 11, 2004 11:46 pm Post subject: |
Welcome! :D
This has been noticed before and apparently the POI disappearing is a "feature" of CoPilot. Personally, I think it is a negative feature. :x _________________ Gone fishing! |
Posted: Fri Nov 12, 2004 12:05 am Post subject: |
thanks for the reply.
a feature, really ? I'd been through several reviews and every screenshot showed a moving icon with various POIs visible. I assumed they were normally there and that I had some sort of problem. I must have also missed where this 'feature' was mentioned in the manual !
Sorry for not checking more carefully and thanks for clearing it up for me. _________________ - spacerace - |
Dave Frequent Visitor
![](modules/Forums/images/avatars/92698813943397cac09a13.gif)
Posted: Fri Nov 12, 2004 10:02 am Post subject: |
I don't know the exact reason why POI's are only viewable when stationary, but I'll drop a suggestion in here. TomTom Mobile has been having huge problems displaying over 1000 POI's on a map, I believe this is due to the low (or lack of) memory available on the SmartPhones, so it's quite possible that this has been disabled to stop a dramatic slow down in CoPilot. |
stuartm Lifetime Member
![](modules/Forums/images/avatars/gallery/031.gif)
Joined: 21/03/2003 10:37:20 Posts: 116 Location: Barkham
Posted: Fri Nov 12, 2004 10:22 am Post subject: |
They will have difficulty showing large numbers of POIs but it shouldn't be a problem to display the few that will be visible at the sort of zoom levels you get whilst driving. On one of the few times I've actually had a response from ALK they said that the disappearing POIs was designed that way to avoid distracting the driver. |
Posted: Fri Nov 12, 2004 11:13 am Post subject: |
you see I don't find them a distraction at all. In fact it's easier to check your real progress matches the indicated progress by seeing if you do in fact have a petrol station on your right, than a road junction etc.
also if you're driving down the motorway a visual indication of a hotel or petrol station approaching simply isn't going to happen ! I suppose you have the notifications but few people have them switched on for every category. _________________ - spacerace - |
Posted: Fri Nov 12, 2004 11:15 am Post subject: |
Dave wrote: | I don't know the exact reason why POI's are only viewable when stationary, but I'll drop a suggestion in here. TomTom Mobile has been having huge problems displaying over 1000 POI's on a map, I believe this is due to the low (or lack of) memory available on the SmartPhones, so it's quite possible that this has been disabled to stop a dramatic slow down in CoPilot. |
but if I switch views (say to 3d map) it shows all the POIs quite happily until I halt and resume again, at which point they promptly disappear ! doesn't seem to produce any memory errors / problems.
also I understand the safety argument, but it really should be a switchable menu option. _________________ - spacerace - |
