Pocket GPS World :: View topic - urgent help required
kblackburn
PostPosted: Sat Nov 20, 2004 10:50 pm    Post subject: urgent help required Reply with quote
This just gets worse, i earlier downloaded checkpoint3.2, but couldn't get it to run, so sought advise from this forum, removed it as suggested and installed version2.0, this will not run either, i now have two icons in my programs folder and clicking on either dont get any response, what's going on !!!. should it be stored on the sd card or somewhere else, i seriously need assistance with this, step by step if any one can help.
kevin
alix776
PostPosted: Sat Nov 20, 2004 11:08 pm    Post subject: Reply with quote
it should be stored on the ppc as it intergrates with tomtom if you could give us more info on the problem maybe we could help of have a look through the checkpoint forum first
device Lumia 950 xl
DavidW
PostPosted: Sun Nov 21, 2004 3:20 pm    Post subject: Reply with quote
If you have left over icons from programs you've uninstalled, you can browse into \Windows\Start Menu, find and delete the respective link (which may be in a sub folder).
You can either use a program on the Pocket PC to do it (the built in File Manager, or something like Resco Explorer 2003), or you can use ActiveSync's Explore feature. Start out selecting "My Pocket PC", then Windows and Start Menu.
kblackburn
PostPosted: Sun Nov 21, 2004 7:17 pm    Post subject: Reply with quote
Hi David,
ok, gone into active sync/ explorer/my ppc/
windows& start menu. deleted the checkpoint version3 icon. great.
But on the ppc, the ion for checkpoint 2.0, when you touch the icon with the stylus it gives the impression that it's giong to work, but nowt happens.
whats next. do i uninstall this and buy GPSAssist or what, or is it me being totally thick Embarassed
DavidW
PostPosted: Sun Nov 21, 2004 9:08 pm    Post subject: Reply with quote
Are you sure there's not a little blue icon down at the bottom right of your Today screen when you run CheckPOInt? If there is, tap it (it may be a tap and hold) and the CheckPOInt menu should appear so that you can set it up.
kblackburn
PostPosted: Sun Nov 21, 2004 9:30 pm    Post subject: Reply with quote
Hi David,
right, i've got the little icon, bottom right of today screen, i've set the general and international settings, but when i go to navigator properties, can find OTHER PROPRETIES as listed in the checkpoint instructions, scroll down, no pocketgps-uk or anything else to do with speed cameras.
an you help again, i downloaded pgsspeed cameras from this site, so it must be somthing i'm doing wrong.
kevin
DavidW
PostPosted: Sun Nov 21, 2004 9:41 pm    Post subject: Reply with quote
Assuming that you've unpacked the file you've got and put the .ov2 and .bmp files in the appropriate map folder, you should be able to select the POIs in TomTom Navigator. If not, you need to solve that problem before going any further with CheckPOInt.
If you have the POI files available in TomTom Navigator, it's then a case of activating the warnings you want in the Overlay Settings screen of CheckPOInt. Most people choose to tell CheckPOInt to start Navigator when CheckPOInt is started, and shut down when Navigator is shut down. That way, you just select CheckPOInt to start navigating.
If you do this, you can get back to the settings by starting CheckPOInt, switching back to the Today screen, and accessing the CheckPOInt icon that way.
kblackburn
PostPosted: Sun Nov 21, 2004 9:44 pm    Post subject: Reply with quote
David,
do i have to copy each file over indivually,
kevin
DavidW
PostPosted: Sun Nov 21, 2004 9:54 pm    Post subject: Reply with quote
It depends what you're trying to do. If you're trying to install from the Zip file, yes - make sure you put the files into your map folder.
It may be easier to set up POIedit to use the POIsync service with Pocket GPS World. You only have to sort it out once - you can then use the features to keep your POI files up to date when they're re-released periodically. Do make sure you have an active ActiveSync connection to your Pocket PC when you start POIedit.
kblackburn
PostPosted: Sun Nov 21, 2004 10:05 pm    Post subject: Reply with quote
David,
right, done it , i copied all files seperetly and now there where they should be. Thanks very much for your help, i'm off out to try now.
any problems and i'll be back.
kevin
DavidW
PostPosted: Mon Nov 22, 2004 3:47 pm    Post subject: Reply with quote
Well done! It's a bit of a steep learning curve, but you have hopefully come out from it having learnt rather more about Pocket PCs and handling files.
