RichardN Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_sp_016.jpg)
Posted: Tue Sep 14, 2004 9:59 am Post subject: Beginners question about TomTom Go |
Hi there - sorry if this is obvious but can any users of the Tomtom Go unit tell me if it shows your position at all times or only when you have set up a route? I am thinking about the POI detection of Safety Cameras. Will it warn you when you are driving around locally (i.e. not using route finding)?
Thanks... |
Powelly131 Occasional Visitor
Posted: Tue Sep 14, 2004 12:27 pm Post subject: |
Yes it does work as long as the unit is switched on! |
Dave Frequent Visitor
![](modules/Forums/images/avatars/92698813943397cac09a13.gif)
Posted: Wed Sep 15, 2004 2:11 pm Post subject: |
It will not warn you of cameras if you don't have a route planned. |
MrRubberGloves Regular Visitor
![](modules/Forums/images/avatars/7402845004294818d29214.jpg)
Joined: May 09, 2004 Posts: 163 Location: Blackpool, England.
Posted: Wed Sep 15, 2004 4:07 pm Post subject: |
Dave wrote: | It will not warn you of cameras if you don't have a route planned. |
Mine does. ![Confused](modules/Forums/images/smiles/icon_confused.gif) |
Posted: Wed Sep 15, 2004 5:33 pm Post subject: |
Thanks for your replies however the conflicting tales leaves me unsure as to the answer. Mr Rubbergloves - did you have to set it up in a special way or did it work out of the box? |
Posted: Wed Sep 15, 2004 5:43 pm Post subject: |
RichardN wrote: | Thanks for your replies however the conflicting tales leaves me unsure as to the answer. Mr Rubbergloves - did you have to set it up in a special way or did it work out of the box? |
If you are talking about the speed cameras, then I downloaded them off this site, unzipped then installed them onto my TT Go via my computer. Turned on my TT Go, the touched the screen, then pressed CHANGE PREFERENCES, then the RIGHT ARROW, the MAINTAIN POI, then WARN WHEN NEAR POI, then selected the UK GATSO, I then set the distance, then selected the warning sound and finally I left the box unticked when I was asked "Warn only if POI is on route?". |
bobmorris Lifetime Member
Posted: Wed Sep 15, 2004 6:07 pm Post subject: |
So does mine! |
Gus607 Occasional Visitor
Posted: Wed Sep 15, 2004 7:10 pm Post subject: |
And mine !!! |
Darren Frequent Visitor
Posted: Wed Sep 15, 2004 8:32 pm Post subject: |
Yes, it will warn of cameras with or without a route planned. This is an option in the POI Detection config, to warn only on a programmed route or to warn at all times.
Apologies for the misinformation. _________________ Darren Griffin |
Posted: Wed Sep 15, 2004 10:46 pm Post subject: |
Thanks for your help folks. That's decided me to get one. |
Posted: Wed Sep 15, 2004 11:44 pm Post subject: |
![Not Worthy](modules/Forums/images/smiles/11.gif) |
endoman Occasional Visitor
Posted: Thu Sep 16, 2004 7:57 am Post subject: |
Got mine yesterday, updated and downloaded cameras in 10 minutes, and out for a test run. Worked an absolute dream. Just make sure you don't tick the warn on route box if you want to see the warnings without a planned route. |
MikeB Frequent Visitor
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Mike.png)
Posted: Thu Sep 16, 2004 8:15 am Post subject: |
You also need to be a bit wary relying on the warn on route option as some cameras may be recorded incorrectly, or be slightly off route, or recorded from the wrong side of a dual carriageway. None of these will produce a warning. _________________ Mike Barrett |
