Pocket GPS World :: View topic - Ipaq 3760 / Fortuna U2 (Serial) / TomTom Navigator 3 - setup
ajhunt
PostPosted: Tue Jul 27, 2004 1:55 pm    Post subject: Ipaq 3760 / Fortuna U2 (Serial) / TomTom Navigator 3 - setup Reply with quote
Hopefully this should be fairly straightforward. I have just bought the above with no instructions on the configuration of the GPS with TomTom.
Can someone give me a definative answer at to which GPS and on which port I should configure the TomTom GPS Status program to get this working?
Many thanks
Andy
lbendlin
PostPosted: Tue Jul 27, 2004 2:14 pm    Post subject: Reply with quote
NMEA 4800 on COM1
Lutz
TomTom/TeleAtlas NAVTEQ
ajhunt
PostPosted: Tue Jul 27, 2004 2:17 pm    Post subject: Reply with quote
Thanks - I'll give that a try
tungstentim
PostPosted: Wed Jul 28, 2004 6:31 pm    Post subject: Reply with quote
I've just got tomtom nav. along with a rikaline 6010 reciever and can't open COM1 any ideas ?
Thanks in advance,
TTim
Question
lbendlin
PostPosted: Wed Jul 28, 2004 8:02 pm    Post subject: Reply with quote
What Pocket PC do you have? Any external keyboard connected?
Lutz
tungstentim
PostPosted: Wed Jul 28, 2004 10:09 pm    Post subject: Reply with quote
your spot on, I'vr just fixed it by removing the hp micro keyboard update thingy. Now it works fine and dandy.
Thank you very much for the reply though.
TTim Wink
ajhunt
PostPosted: Thu Jul 29, 2004 1:36 pm    Post subject: Still not working Reply with quote
As suggested, I'm using the NMEA driver on com1 and still haven't successfully been connected.
It's been pretty cloudy over the fast few days. It's been suggested this could be the factor - is this true?
I've been trying over periods anything upto a couple of hours. Can I leave the GPS unit powered up but without the PDA on and it will still acquire a lock?
I've confirmed that I have no external keyboard driver loaded and the InfraRed is off.
Any help would be greatly appreciated.
lbendlin
PostPosted: Thu Jul 29, 2004 1:48 pm    Post subject: Reply with quote
Maybe your Fortna receiver is set to another baud rate or even to SiRF. Leave the connector setting at COM1, and try the other speeds.
Lutz
ajhunt
PostPosted: Thu Jul 29, 2004 2:02 pm    Post subject: Reply with quote
How long should I try each one for before trying another and do I have to reset the PDA or program each time?
lbendlin
PostPosted: Thu Jul 29, 2004 2:15 pm    Post subject: Reply with quote
Simply set the speed, check the mark, and then switch over to the first tab and see if the black dots are running. If not, keep trying. If yes you are done and should see some grey and then red bars.
No need to reset in between.
Lutz
22.062 (12 Jun 24)
