Pocket GPS World :: View topic - speed camera Database
Pirate3000
PostPosted: Fri Oct 21, 2011 9:30 am    Post subject: speed camera Database Reply with quote
Has anyone got or still working the workaround that was posted here to allow the database to work on the iphone app?, as now that I have upgraded to IOS5 it has stopped working..
this is the link to the details fo this.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=85133&highlight=
thanks
Not Lost Yet!! But Jane is always there to help
PostPosted: Fri Oct 21, 2011 9:45 am    Post subject: Reply with quote
And that is one of the reasons why we don't recommend it as a solution. It was always a hack and could be taken away with an update to the app or the OS.
Why not ask in the thread that you linked to?
PostPosted: Fri Oct 21, 2011 10:16 am    Post subject: Reply with quote
The upgrade to iOS5 will have caused a re-load of the TomTom app which will be devoid of the files you added to get the speed camera warnings working, re-install in line with the instuctions and it will be fine - Mike
Pirate3000
PostPosted: Fri Oct 21, 2011 10:26 am    Post subject: database Reply with quote
I have but it still dont want to work again..
PostPosted: Fri Oct 21, 2011 10:30 am    Post subject: Reply with quote
Usual issues:
Check the TomTom app isn't running in the background when you copy the mapsettings.cfg file over to the app.
Make sure you put the mapsettings.cfg file in the correct folder.
Have you added a set of Speed zoned ov2 files to the files downloaded from the page Darren limked to - Mike
Pirate3000
PostPosted: Fri Oct 21, 2011 10:45 am    Post subject: database Reply with quote
The app is not running when i copied the file over and it still wont work.
I had this ages ago and then got it to work again.
i think i will copy the mapsettings file from my old one xl and see if that helps.
Enri
PostPosted: Fri Oct 21, 2011 11:25 am    Post subject: POIs on iPhone TomTom app. Reply with quote
I have the same problem but also cannot use any of my personal POIs I transfer over to the iPhone either. None of the POIs show up in the POI listing.
iPhone TomTom v1.8 and IOS5.
PostPosted: Fri Oct 21, 2011 12:24 pm    Post subject: Reply with quote
Perhaps you want to try using the TomTom V1,9 app thats just hit the app store as a free update - Mike
wazzzzupmate
PostPosted: Fri Oct 21, 2011 1:38 pm    Post subject: Reply with quote
I too have upgraded to Tomtom 1.9 on my iphone 4S running IOS5.
I have reinstalled all the files from here for the camera alerts and no alert is played. I can confirm that TT was not running on the iphone when I copied the files over, and I used the mapsettings config from here. I have also copied over the ov2 files from this weeks update. Sad
Tomtom Go 400
Tomtom 1.15.1 for Iphone
Pirate3000
PostPosted: Fri Oct 21, 2011 1:50 pm    Post subject: database Reply with quote
As was said earlier in the post, this was only ever ahck for it to work, so perhaps its back to PGPSW app..
PostPosted: Fri Oct 21, 2011 1:51 pm    Post subject: Reply with quote
You must be doing something wrong, I have just updated the iPhone4 to iOS5 and updated the TomTom app to V1,9 loaded all the required files in to their respective folders and the app is working fine displaying the PGPSW speed camera icons and playing the ogg audio warnings when running route demo or driving around.
Have any of you removed the TomTom speed camera files while loading the database from this site, I haven't done this step as yet - Mike
wazzzzupmate
PostPosted: Fri Oct 21, 2011 1:55 pm    Post subject: Reply with quote
Copied the mapsettings.cfg file over again and all is working
Tomtom Go 400
PostPosted: Fri Oct 21, 2011 2:04 pm    Post subject: Reply with quote
One slight issue you might notice is the mobile VAR camera category doesn't have an icon, this is because the category has been added to the database since I last updated the icons.
Easy to fix though, just use Paint to save the existing mobile var icon as a 24 bit bmp then save as png and add the resultant file to the map folder along with all the other icon files, if you are running an iPhone4 you might also want to resize the icon to 44x44 as they display better at that size - Mike
Enri
PostPosted: Fri Oct 21, 2011 3:29 pm    Post subject: Reply with quote
Sorry, Was being stupid! Copied the mapsettings.cfg file to the correct folder and all working correctly now!
Embarassed
22.034 (27 Mar 24)
