Newsletter
Pocket GPS World :: View topic - CamerAlert Support
CamerAlert Support
Goto page 1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Mon Dec 21, 2009 3:06 pm    Post subject: CamerAlert Support Reply with quote
If you have problems with the CamerAlert application please check through the forums to see if this is a common issue that we have posted a solution to.
If you still have an issue please post it in this forum section and we will sort it out as soon as possible.
Editor, PocketGPSWorld.com
tjh99
PostPosted: Tue Feb 16, 2010 6:49 pm    Post subject: Fantastic Reply with quote
I have beenusing the pocketgps database for a couple of years now, and have been waiting for the iPhone app.
Works very well and is easy to use.
Thankyou.
This does eat battery life, make sure you have a power lead in your car.
mostdom
PostPosted: Fri Feb 19, 2010 1:48 pm    Post subject: Reply with quote
lbendlin wrote:
That's a known limitation. Sound control only works when a sound is currently playing (Thanks Steve!) and our announcements are not long enough to give you sufficient time for the adjustment.
I think this continues to work after the first sound is played until shutdown.
I suggest playing a silent sound file on startup may resolve this. Worth a try!
Dom
mostdom
PostPosted: Fri Feb 19, 2010 1:53 pm    Post subject: Reply with quote
Sorry above post is moved from the camera alert anouncment page, looks a bit stupid now on it's own. Embarassed
Still it might be a fix for the volume control problem, so might be worth a try on the next beta test!
Dom
ben_e71
PostPosted: Mon Feb 22, 2010 10:23 am    Post subject: Reply with quote
I can't seem to link my phone to my account - the only option I get is to register ... am I being slow
also I have two iphones one for work and one for home does this mean I can ony use this on one of my phones?
thanks
Ben
ben_e71
PostPosted: Mon Feb 22, 2010 10:29 am    Post subject: Reply with quote
okay worked that bit out you had to register to link.
However, I think this linking to one device (although I can see why you do it to prevent giving it to mates) is a bot unfair.
I have a tom tom which I will use when going somewhere new and two iphones but I can only add the up to date speed cameras to one device without paying 19.99 for each.
nobubbles
PostPosted: Sun Feb 28, 2010 11:37 am    Post subject: CamerAlert on iTouch? Reply with quote
Would I be able to use CamerAlert on an iTouch with a Tomtom mount?
PostPosted: Sun Feb 28, 2010 11:40 am    Post subject: Re: CamerAlert on iTouch? Reply with quote
No, because the app needs the data connection for the map, speed camera downloads/ submissions - Mike
chillpete
PostPosted: Sun Feb 28, 2010 5:34 pm    Post subject: cameralert Reply with quote
I cannot open this app most of the time, and when I do get it open it crashes again after a few seconds. I have had the app now for about a week and never been able to use it yet.
Is there anyone out there that can help
Peter
PostPosted: Sun Feb 28, 2010 6:11 pm    Post subject: Re: cameralert Reply with quote
Peter
Peter,
The app shutting on its own is strangely not always the app crashing, but a 'feature' of the iPhone operating system. When the system is short of memory the OS shuts down applications, making them appear to crash.
Have you tried doing a hardreset of the iPhone by holding the power button for about 10 seconds then sliding the reset slider? This is like booting a computer and starts off with clean memory again.
Despite the iPhone OS not allowing user tasks to run concurrently there are a number of system tasks that can run in the background including Mail, Safari, and the iPod all of which consume memory and over time can eat up all the system memory.
chillpete
PostPosted: Sun Feb 28, 2010 6:45 pm    Post subject: Reply with quote
HI Mike,
yes I have tried that 3 or 4 times and still no joy, the only time I can get it to work is if I uninstall and reinstall the app then it will work for a short time before it crashes again.
Peter
PostPosted: Mon Mar 01, 2010 2:34 am    Post subject: Reply with quote
for those with the 'crashing' problems... if you uninstall, reboot, then reinstall and run the app can you check in the settings to see if the 'track log' option is on or off?
i wonder if something is using up extra memory eg the track log recording in the background?
batties
PostPosted: Mon Mar 01, 2010 1:31 pm    Post subject: Reply with quote
When I charge the iphone 3g via my car charger the CamerAlert app all works fine apart from there is no sound warning? Is this because I have it on permanent charge? (Which I need to do when running this app as it eats the battery life). Any help with this would be greatly appreciated.
TT Go 720 v8.204
Western Europe Map v8.45
8 GB SDHC card
TT Home version 2.7.5.2014
iPhone 4S with CameraAlert
chillpete
PostPosted: Mon Mar 01, 2010 3:03 pm    Post subject: Reply with quote
Hi,I tried this and it worked for a while, that is until I closed the app and tried to re start it, then it just crashed again Sad
Peter
lbendlin
PostPosted: Mon Mar 01, 2010 4:37 pm    Post subject: Reply with quote
While connected to the car charger run the iPod app to confirm that your music volume is set loud enough. Also check the mute switch on the side of the device.
Lutz
TomTom/TeleAtlas NAVTEQ
Page 1 of 8
18.113 (18 Nov 20)
Terms & Privacy
