Pocket GPS World :: View topic - 1490 LMT Maps
1490 LMT Maps
paradime
PostPosted: Tue Nov 08, 2011 5:44 pm    Post subject: 1490 LMT Maps Reply with quote
Have just got new 1490 LMT which seems great but is there any way that I can view the GPS installed maps (lifetime Europe) on my PC ?? Would be nice to be able to plot routes and waypoints in this way just like I did on my old Mapsource DVDs for my Streetpilot i3
Thanks a lot
Peter
PhilHornby
PostPosted: Tue Nov 08, 2011 6:16 pm    Post subject: Basecamp Reply with quote
Garmin Basecamp should do the trick ...
http://www8.garmin.com/support/download_details.jsp?id=4435
willton
PostPosted: Fri Nov 11, 2011 5:45 pm    Post subject: Reply with quote
that basecamp sw is more for trails etc. Mapsource will allow you to plot routes and waypoints and download them to your device.
When you connect your device to the garmin map updater it should give an option to install on PC as well so you can use mapsource with it.
Thats how my 3760 works.
paradime
PostPosted: Fri Nov 11, 2011 6:11 pm    Post subject: Thanks for information Reply with quote
Thanks both of you for the replies which were most helpful. Yes, I find that the mapsource seems the best for routing
Regards Peter
PostPosted: Fri Nov 11, 2011 6:17 pm    Post subject: Reply with quote
I too find Mapsource more user friendly than Basecamp, however Garmin are no longer supporting Mapsource and it won't work correctly with the newer models.
Routing however should be the same for both, provided they're using the same mapset. Note that neither send the route to your nuvi, but simply the waypoints you've entered. Your nuvi will recalculate the route depending on the settings it has for routing, eg avoid toll roads, shortest route etc.
paradime
PostPosted: Sat Nov 12, 2011 4:25 pm    Post subject: Reply with quote
I downloaded the latest version of Mapsource and it uploads routes.waypoints etc to my 1490 LMT.
I found with Basecamp that couldn't delete anything ! Normally you can do that by right clicking, but I never found out how to do it !!!
Peter
PostPosted: Sat Nov 12, 2011 6:13 pm    Post subject: Reply with quote
Right click and delete works with Basecamp Wink
22.043 (17 Apr 24)
