Pocket GPS World :: View topic - New Map Problem
New Map Problem
big_phil555
PostPosted: Sat Mar 12, 2011 6:03 pm    Post subject: New Map Problem Reply with quote
I have just installed the update to GB/Ireland - this works fine.
At the same time, I also purchased Southern Europe and this down loaded and is on the SD card (TT1 with the removable SD card 4N00.004)).
When I input a destination, I only get GB/Ireland - I can not 'see' the europe map, even if I set my destination to say Paris
Any ideas or advice?
thanks
PostPosted: Sat Mar 12, 2011 6:30 pm    Post subject: Reply with quote
If you have two maps installed, you can only use one at a time.
You need to "switch map" in the settings menu (probably under "Manage maps").
Once you are "looking at" the Europe map, when you want to search for a city, you should see a small country flag on the right of the text entry window. Tap on that flag to change the country being searched.
big_phil555
PostPosted: Sat Mar 12, 2011 6:33 pm    Post subject: Reply with quote
many thanks for a quick reply
works fine Embarassed
PostPosted: Sat Mar 12, 2011 6:36 pm    Post subject: Reply with quote
You don't know how happy that makes me!
I've had awful 'flu and my brain has been working like cold porridge.
That answer was possibly the first bit of sense I've managed to produce in days!
big_phil555
PostPosted: Sat Mar 12, 2011 9:24 pm    Post subject: Reply with quote
glad you are better mate Cool
once you are in say the France map, how do you change to spain for example?
thanks
DOH Embarassed touch the map symbol and change country Embarassed
AliOnHols
PostPosted: Sat Mar 12, 2011 9:47 pm    Post subject: Reply with quote
No need to do that, the Europe map is continuous. You only need to change countries when searching for an address/POI etc.
Garmin Nuvi 2599
SatMap Active 10 & 20.
big_phil555
PostPosted: Sat Mar 12, 2011 9:55 pm    Post subject: Reply with quote
cheers mate Cool
22.034 (27 Mar 24)
