Pocket GPS World :: View topic - POI Camera Warnings disappear when New Maps Uploaded
chunkyis
PostPosted: Fri Jan 21, 2011 6:33 pm    Post subject: POI Camera Warnings disappear when New Maps Uploaded Reply with quote
Hi, I wonder if you can help me. I've got a Tom Tom Rider (original) for my bike and a Tom Tom Go 750 Live for my car. Every time I download a new map to either of the devices, I lose the PocketGPS World Camera Warnings, and have to manually set up each particular camera type which is a very laborious task. Is there a file in the device on which these settings are stored which I can copy & paste across after the new maps have been downloaded.
Many thanks
Chunky
PostPosted: Fri Jan 21, 2011 6:38 pm    Post subject: Reply with quote
Look for 'MapSettings.cfg' in the old map folder. Save it.
After the new map is installed, copy that file to the new map folder (overwriting the new one.
Normally works fine, but if it causes re-booting you can either
1. connect to TT Home and add a new favourite
2. remove it again.
PaulB2005
PostPosted: Fri Jan 21, 2011 6:42 pm    Post subject: Reply with quote
Assuming you have a backup copy the mapsettings.cfg file can be copied to the new map installation.
If the unit then continuously reboots you can try using the Operate My GO function in Home to add a favourite. If that doesn't work you might have to delete the file and start again.
BTW this has been asked numerous times and a search might have been quicker to find the answer! Wink
PostPosted: Fri Jan 21, 2011 6:52 pm    Post subject: Reply with quote
mapsettings.cfg would indicate iPhone app by TomTom.
MapSettings.cfg indicates a standalone Nab unit from TomTom.
The spelling is important though, if you put the wrong one on a device the software will ignore it - Mike
chunkyis
PostPosted: Sun Jan 23, 2011 11:40 pm    Post subject: POI Camera Warnings disappear when New Maps Uploaded Reply with quote
Many Thanks Guys !!
Chunky
PostPosted: Mon Jan 24, 2011 10:56 am    Post subject: Reply with quote
And there isn't a mapsettings.cfg on the Carminat TomTom SD card! Evil or Very Mad
PostPosted: Mon Jan 24, 2011 5:53 pm    Post subject: Reply with quote
The spelling is important though...
Skitt's Law strikes again! Very Happy
KenDuggan
PostPosted: Thu Mar 03, 2011 1:36 pm    Post subject: Map Settings problem. Reply with quote
I use a GO 720, and have had this 'lost settings' frustration with TomTom every time I update my maps. I have tried copying and pasting mapsettings.cfg into the Western Europe map file every which way, I have tried the 'create a favourite using Home' route to generate a mapsettings file, all to no avail. As soon as I add in the 'old' mapsettings file, the device goes into a mode where it switches itself off once it is midway through its bootup routine.
Is there anything about a 720 that prevents this fix from working; or does anyone have any experience with a 720 that might help me? Thanks; I'm bald enough already, this is removing the final strands of my thatch!
PostPosted: Thu Mar 03, 2011 8:20 pm    Post subject: Re: Map Settings problem. Reply with quote
Only thing I can think of is - Are you disconnecting from the computer properly?
Click Device... Disconnect Device...
When it says OK to disconnect, DO NOT disconnect. Click the OK button then wait for the device to boot up again. When it asks if you wish to connect to computer choose NO, then wait for the device to complete loading, then when it shows the map normally, switch off and disconnect.
PS A poke down the reset hole never does any harm.
PostPosted: Fri Mar 04, 2011 1:17 am    Post subject: Reply with quote
I'm not going to make friends here.... Laughing
How often do you update the maps?
Re-building the entire MapSettings.cfg settings from scratch takes me about 10 minutes, even re-doing all the PGPSW camera warnings.
Even if you bought every single map update that's only 10 minutes every three months.
As there is very little improvement in each successive map, I would only update once a year or so. Ten minutes a year doesn't seem too bad to me!
Quicker than loading up Home, adding a Favourite, disconnecting and finding it still doesn't work.
PostPosted: Fri Mar 04, 2011 9:03 am    Post subject: Reply with quote
But I have to agree with you. My only problem is that when it happens to me, I have always forgotten that it happens, so I'm away down the motorway before it suddenly strikes me that all is quiet, so I have to find the next Service Area to put it right, or on ordinary roads a convenient layby (and when can you find a layby when you need one?).
KenDuggan
PostPosted: Fri Mar 04, 2011 9:49 am    Post subject: Reply with quote
Go to the top of the class, Dennis!
Thank you, all. Avoiding physically disconnecting and adding a Favourite worked a treat.
22.044 (24 Apr 24)
