Pocket GPS World :: View topic - Nissan Connect not reading memory stick
BAZ9
PostPosted: Wed Feb 03, 2010 7:35 pm    Post subject: Nissan Connect not reading memory stick Reply with quote
Can anyone help, I have downloaded the files on to a memory stick as instructed but when I plug the memory stick in my Nissan Connect I get usb found on the screen then nothing else what am I doing wrong
PostPosted: Wed Feb 03, 2010 9:52 pm    Post subject: Reply with quote
Have you read through the other topics in this section?
For example THIS ONE?
BAZ9
PostPosted: Thu Feb 04, 2010 7:23 pm    Post subject: Reply with quote
I have tried space and no space still no joy
BAZ9
PostPosted: Mon Feb 08, 2010 8:25 pm    Post subject: Reply with quote
Seem to have cracked it at last
Found out that I had to name the folder as follows
MyPOIs / MyPOIWarnings( note the upper case M's and no spaces) This configures with the wording of MyPOIs on the Nissan Connect Screen. Then after loading the files plug in to your connect usb it will read usb found then press set up button then touch navigation then scroll down to load My POI Warnings and touch then it should load your files if it seems to be taking a long tine just turn the volume knob slightly just to give it a nudge it should then load which just takes a few seconds.
Hope this is of some use if you are having Problems.
BAZ9
PostPosted: Mon Feb 08, 2010 8:57 pm    Post subject: Reply with quote
My POIs My POIWarnings( note the upper case M's and no spaces)
Well done Baz...
So just to make it crystal clear, are you saying that:
1. at the top level of the USB stick you make a folder called - My POIs
and:
2. Inside that folder you make a sub-folder called - My POIWarnings
Is that right?
BAZ9 wrote:
if it seems to be taking a long tine just turn the volume slightly just to give it a nudge
Laughing That knob -ing word censor again! You can't even say "knob"!
You should have said "volume tit" instead. That gets through!
BAZ9
PostPosted: Mon Feb 08, 2010 11:37 pm    Post subject: My POIs Reply with quote
yes thats correct but with no spaces so it will read MyPOIs / MyPOIWarnings
BAZ9
jga40
PostPosted: Tue Feb 09, 2010 5:49 pm    Post subject: Re: My POIs Reply with quote
BAZ9
It's not necessary to use upper case 'M'' in MyPOIs nor in MyPOIWarnings, lower case 'm' work. I've uploaded two updates both of which uploaded fine.
My Nissan Quasqai bought in Jan 2010 had no Nissan Connect handbook with it, but and I've received one dated 2009, and it clearly states to use lower case 'm' for both folders.
All in all, I'm very disappointed with the GPS side of Nissan Connect. When it detects a camera, there's a faint bleep and information flashed on the screen for a few seconds to tell the user the type of camera they're approaching. No icons to show camera type, nor any speed warnings for say 30 mph and 60 mph zones.
My Garmin i3 Pilot now in my wife's car gives full information about cameras and speed and cost a lot less than £100. I understand Nissan Connect costs around £400 if not fitted as standard.
Great car, lousy Sat Nav system. Nissan, get your act together !!!
Jim
PS Will check the latest download later with my Text Editor and compare it to an earlier download an report back.
PostPosted: Tue Feb 09, 2010 7:10 pm    Post subject: Reply with quote
In other words, exactly as I state in the installation guide!
BAZ9
PostPosted: Tue Feb 09, 2010 7:28 pm    Post subject: Reply with quote
Sorry but mine wouldn't load with lower cace m's I tried several timesIt is worth trying if you are having problems
PostPosted: Tue Feb 09, 2010 7:32 pm    Post subject: Reply with quote
The lower case 'm' is as described in Nissan's Connect manual.
PaulB2005
PostPosted: Tue Feb 09, 2010 8:01 pm    Post subject: Reply with quote
Do these units have an information screen that might show the software / hardware version on these units? Wondering if the requirements change from build to build...
jga40
PostPosted: Tue Feb 09, 2010 9:40 pm    Post subject: Nissan Connect Reply with quote
Will check out tomorrow when it's light and report back.
Sorry for any delay, but I'm a disabled wheelchair user.
Jim
PostPosted: Tue Feb 09, 2010 10:22 pm    Post subject: Reply with quote
So it either needs spaces.......or it doesn't.
And it needs capital letters..... or it doesn't.
Crying or Very sad
BAZ9
PostPosted: Tue Feb 09, 2010 11:32 pm    Post subject: Reply with quote
Yes just try it in different formats that's how I got it to load. I got no joy with the recomended format so I tried different ones till I got it to load as with upper case Ms and no spaces
PostPosted: Mon Mar 22, 2010 12:22 am    Post subject: Reply with quote
Also see HERE
22.043 (17 Apr 24)
