Phil-the-Fluter Occasional Visitor
Posted: Thu Jul 30, 2009 1:52 pm Post subject: TT Go 510/710 Reset |
I'm having trouble with my unit. Everytime I press the on button, all I get is the tomtom two hand sign and the sound clip that goes with it, then it closes down after 10 seconds. This happens everytime. Having read the instruction book, there is nothing about the reset. Does anyone know how long to hold down the reset and do you do it in conjunction with anything else?
Thanks |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Thu Jul 30, 2009 6:35 pm Post subject: |
I don't think it matters how long you hold down the reset button but some people say that there are two types of reset, one a short poke and the other holding the reset button down for 30 seconds. Why not try both.
If you are getting the drum roll sound then the reset is probably working.
Can you access the data on your tomtom when you connect it to a computer? _________________ Paul |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Thu Jul 30, 2009 7:25 pm Post subject: |
On the x10 series the Reset is a pin-in-the-hole job on the underside of the Unit.
Having said that the drum roll usually indicates that the unit has reset.
With the unit off, try taking the SD Card out, then re-insert it. Switch the unit on. _________________ Richard
Posted: Fri Jul 31, 2009 2:14 pm Post subject: Tried and tried |
Thank you both for your suggestions. I've tried every combination of holding start, not holding start, short spike reset, long hold reset. I keep getting the two hands and the drum roll then it closes down. Tried taking the SD card out and putting it back, probably tried things that even their R&D guys haven't thought of. No joy. looks like I'm heading towards my wallet for the first time in 2 long years.
Thanks again.
Posted: Fri Jul 31, 2009 6:01 pm Post subject: |
Don't give up yet!
Do you have a card reader for your PC? If so can you see any data on the tomtom card.
If not can the PC see the data on the tomtom card when the tomtom is connected to the PC? _________________ Paul |
Posted: Mon Aug 03, 2009 8:56 am Post subject: |
I used my PDa to see if there was anything on the SD, it all appeared to be there. But I'm not sure if there was anything missing so thats all I know. |
Posted: Mon Aug 03, 2009 5:46 pm Post subject: |
Do you have a backup of the data from your SD card on your PC? If so you could try copying the data to a new SD card and posting back here with the result. _________________ Paul |
