Pocket GPS World :: View topic - Route Share
Route Share
FrequentFlyer
PostPosted: Tue Jul 07, 2009 8:25 pm    Post subject: Route Share Reply with quote
I've just uploaded my first route to Map Share , but now realise that I should expand the information, (as I wasn't sure how much room I had to play with,)
Is it possible to go back and amend, (or delete and start again ?) Thanks.
LostMike
PostPosted: Wed Jul 08, 2009 6:50 pm    Post subject: Reply with quote
You don't seem to have caught our attention!
If you log on to route share and then select "my routes" it will list all of the routes that you have uploaded. At the bottom right of each entry are the options "delete route"/"edit route". Hopefully that will give you what you want.
Good luck.
LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525
Physicist
PostPosted: Thu Jul 09, 2009 5:53 pm    Post subject: Reply with quote
When I attempt to open a saved route in Route Panner the screen freezes and the route is not shown. I am using Vista. All other functions in Route Planner work fine. The saved route is in gpx format. Help!
FrequentFlyer
PostPosted: Wed Jul 15, 2009 9:42 pm    Post subject: Reply with quote
[quote="LostMike"]You don't seem to have caught our attention!
Good luck.[/quote
Thanks for that.....I've been away and missed your response.
I did send Satmap the same question but heard nothing....also, would they mind switching West Sussex and East Sussex around !!! (As shown on their county map share map !)
jonesbach
PostPosted: Thu Jul 16, 2009 5:56 pm    Post subject: Reply with quote
Sorry, I missed this earlier. How large is the file? There is an issue with the planner grinding exceedingly slow or not at all on large files.
Physicist
PostPosted: Fri Jul 17, 2009 12:11 am    Post subject: Reply with quote
Not sure of the actual file size but each route was obtained by converting a day's hiking trail (typically 10 -12 miles) into a route saved on the receiver. Once in a blue moon the route does open on the computer but it is very unpredictable and it disappears when I zoom in
jonesbach
PostPosted: Fri Jul 17, 2009 11:17 am    Post subject: Reply with quote
The problem manifests in many ways and has been discussed previously at the address below. If you would like to try compacting the file please PM me your email address - I can't attach files to a PM.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=76680&highlight=
