cartman Occasional Visitor
Posted: Thu Mar 20, 2008 2:47 pm Post subject: Bluetooth problem with iPAQ 214 |
When I try & run TT6 , I get the message
"The Bluetooth Radio failed to turn on due to insufficient driver memory available. You must perform a normal reset before you can turn on the Bluetooth radio"
I've tried that but the message just comes back again. The Bluetooth works ok with my mobile phone so I guess there's a software glitch with TT. Any clues please ?
ETC |
hdv Occasional Visitor
Posted: Thu Mar 20, 2008 11:52 pm Post subject: mine works fine |
I have been using my iPAQ 214 with TomTom v. 6.030 for a while and never found such problem. Which TT version are you using? |
Posted: Fri Mar 21, 2008 12:14 am Post subject: iPAQ 214 |
@ hdv
I have v6.032 (8351)
The message comes up in a box headed BTTrayCE. I've tried uninstalling TTN & then the BT connects perfectly with my GPS receiver so I'm sure it's a TTN problem. I recall a while back it was necessary to modify the registry to stop TTN opening the BT browser but if your system works without that, I can't see why mine shouldn't too !!
ETC |
alan_sh Lifetime Member
Posted: Sat Mar 22, 2008 12:16 pm Post subject: |
TomTom installs 2 DLL's which are older than the original ones for the 214. You just need to rename them, do a soft reset and then delete the renamed ones - the originals will then do the right job.
Now, you are going to ask which 2 DLL's they are - and I can't remember....
So, 1/2 an answer. If I find the names, I'll update this entry. If someone else has the answer, please add to it.
Alan |
Posted: Sat Mar 22, 2008 10:40 pm Post subject: 214 BT problem |
Thanks to you both for taking the trouble to reply.
I'll have a play with the BT files in the meantime & see what I can find , in the hope that someone will come up with the right files to edit anyway !
ETC |
wiz Regular Visitor
Joined: Aug 08, 2005 Posts: 241 Location: Dartford, Kent, UK
Posted: Sat Mar 22, 2008 10:59 pm Post subject: Re: iPAQ 214 |
cartman wrote: |
ETC |
I have version 6.030 (8320) updated from Tom Tom site due to a problem with the display but don't have a problem with BT.
where did you get .032 from?
not had 214 for long, apart from the low sound levels its a gr8 piece of kit
what happens if the BT is already paired and running before you start TT?
hope you sort the problem soon.
Wiz _________________ Alan --- aka Wiz.
Iphone 4S 16gb, ios 5 windows 7, CamerAlert, CoPilot & TomTom |
Posted: Sun Mar 23, 2008 8:44 pm Post subject: 214 BT problem |
OK problem solved !
It occurred to me that the problem started after I'd been playing about with the pairing between my PDA & my phone. I did a hard reset, reinstalled TT & now it works , so I'm assume the BT stack was messed up or a file was corrupted.
Thanks again folks
ETC |
