PeteJohn Occasional Visitor
Joined: Oct 21, 2004 Posts: 27 Location: Ilford England
Posted: Wed Nov 28, 2007 6:27 pm Post subject: GO720 Won't reset |
Can anyone help me please. I have a TomTom Go720 and it will no longer start up. It gets as far as the picture but then will not go any further. When connected to the PC it connects ok but as soon as I click operate my Go then the programme crashes. Thanks |
Andy_P Pocket GPS Moderator
Posted: Wed Nov 28, 2007 6:39 pm Post subject: |
Have you actually done a RESET?
See the TomTom Reset Page for details. |
Posted: Wed Nov 28, 2007 7:19 pm Post subject: |
Yes I meant to have said. I performed a reset but it makes no difference |
Posted: Thu Nov 29, 2007 12:13 am Post subject: |
In that case there is probably a corrupted operating system file somewhere.
Two questions:
Did you do anything (update, add, or move anything in the flash memory, or add an SD card) before this happened?
Did you make any backups before this happened? |
Posted: Thu Nov 29, 2007 4:31 pm Post subject: |
I did try to install the POI Capture and I think this caused the problem. Unfortunately I did not make a back up. If this is a corrupted file is there anything I can do? |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Thu Nov 29, 2007 6:30 pm Post subject: |
PeteJohn wrote: | I did try to install the POI Capture and I think this caused the problem. Unfortunately I did not make a back up. If this is a corrupted file is there anything I can do? | POICapture, at this time, doesn't work correctly with V7 software.
If there is a corrupt system file, I would follow the instructions in This Post.
What you are doing is removing all the system files (those not in the Folders) and then re-installing the software. At this stage ignore the part about Formatting the Card. Just follow the paragraph that starts "Please connect ....".
But PLEASE do a Full Backup using Explorer first. _________________ Richard
Posted: Thu Nov 29, 2007 6:49 pm Post subject: |
Many thanks. I will try this and let you know tomorrow. |
Posted: Fri Nov 30, 2007 7:44 pm Post subject: |
Many thanks for your help everything is now working ok |
