Newsletter
Pocket GPS World :: View topic - CE4.2 or 5?
CE4.2 or 5?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Anquet
pennyandchris
PostPosted: Sat Jan 19, 2008 9:13 am    Post subject: CE4.2 or 5? Reply with quote
Has anyone got Anquet to run on a CE4.2 or 5 device?
I've managed to install to a Road Angel 7000, but it won't run cos' there's no .net framework - which I cannot seem to install.
Any ideas?
philpugh
PostPosted: Fri Jan 25, 2008 3:29 pm    Post subject: Reply with quote
You need .NET V2 framework for Anquet 6 to run - this limits it to the later versions of Pocket PC/Windows Mobile (2003 onwards I think). If you can get a version of CE .NET onto your device then you may stand a chance - but I suspect this is not very likely.
Phil
Brian
PostPosted: Fri Jan 25, 2008 6:10 pm    Post subject: Reply with quote
Microsofts website says you need CE 5.0 or higher to install .NET Compact Framework 2.0, Road Angel is CE 4.2, then you will have the issue of trying to install it in the RA, with some software I've installed it to a Pocket PC then copied and pasted the folder to an SD card and run from there, but it all depends on the software. I often also install CeDesktop to the SD card and try running things from it. I think its all a case of try it and see but I've got a feeling it won't work.
http://www.microsoft.com/downloads/details.aspx?familyid=9655156b-356b-4a2c-857c-e62f50ae9a55&displaylang=en
Aprilia Tuono, Zumo 550
Ipaq 2210/Fortuna/TomTom Nav6
& Road Angel 7000 + Memory Map
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Anquet All times are GMT + 1 Hour
20.065 (29 Jun 22)
