Pocket GPS World :: View topic - help urgently needed
highlander317
PostPosted: Thu Jul 12, 2007 5:55 pm    Post subject: help urgently needed Reply with quote
Received the update disc for my garmin c510 this morning. followed all the instructions and all i get on my unit is " no detailed maps found that support routing. The streetpilot cannot be used without them.
Anyone help?
swing
PostPosted: Thu Jul 12, 2007 9:26 pm    Post subject: Reply with quote
Sounds like either the upgrade failed, or the map unlock code hasn't transferred to the unit properly.
Firstly, can you go through exactly all the steps you went through, confirming all the things along the way - eg did you select the right upgrade option on the DVD menu (there are 2, and only one will work with your unit)....
Secondly, what is on your unit now - if you go to Settings / Map / About what map versions are installed to your unit?
Please don't be offended if I do not reply to a PM - please ask questions via the forums.
highlander317
PostPosted: Thu Jul 12, 2007 10:09 pm    Post subject: Reply with quote
all sorted now thanks for trying
swing
PostPosted: Thu Jul 12, 2007 11:44 pm    Post subject: Reply with quote
Out of interest, what was the problem? By PM if you prefer...
22.043 (17 Apr 24)
