Pocket GPS World :: View topic - garmin city map source routing question
rider2006
PostPosted: Fri Apr 13, 2007 12:19 pm    Post subject: garmin city map source routing question Reply with quote
I am using map source city map and I am trying to get a route from my home to a hotel in france the map finds the points ok but when it routes it goes thru the channel tunnel and I really want dover calais by ferry. I have used the map avoidance feature but it still is routing thru the tunnel any ideas ?
missing_user
PostPosted: Fri Apr 13, 2007 12:37 pm    Post subject: Reply with quote
Put a via at Dover and Calais or mid Channel on the Dover/Calais route.
rider2006
PostPosted: Sat Apr 14, 2007 12:20 am    Post subject: Reply with quote
thanks very much worked a treat map source is quite basic
bumpkin
PostPosted: Tue Apr 17, 2007 9:59 am    Post subject: Reply with quote
I now tend to break such journeys up into sections anyway with a route to the departure port and then another route onward from the disembarkation port. You have plenty of time to select the new route before coming off the ferry and once out of the hull your GPS will pick up a signal and off you go. If the ferry journey is a long one (say Portsmouth - Bilbao) then satellite acquisition might be speeded up by manually changing your position to the disembarkation port or going up on deck before arrival and getting a signal from there.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
22.034 (27 Mar 24)
