Newsletter
Pocket GPS World :: View topic - Detecting Speed Cameras on one side only
Vandome
PostPosted: Tue Jan 13, 2004 7:41 am    Post subject: Detecting Speed Cameras on one side only Reply with quote
Hi, does anyone if it is possible to configure the speed camera POI so it only warns me when the camera is on my side of the road? - as opposed to warning me about cameras on both sides of the road.
Thanx Smile
Howarduk
PostPosted: Tue Jan 13, 2004 3:16 pm    Post subject: Reply with quote
Hi Vandome
The answer is no. Check out this thread when I asked the same question.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=5329&sid=6be0870587745d365a12c623cc1acc70
Howard
Vandome
PostPosted: Tue Jan 13, 2004 8:47 pm    Post subject: Reply with quote
Ah ha!
thanx anyway!
DavidW
PostPosted: Tue Jan 13, 2004 11:31 pm    Post subject: Reply with quote
Just a little plea - if you post links to threads, please trim off the sid element if it's present in the URL - literally cut it off the end of the URL, ending before the &sid
The sid is the session ID for your session. If someone else clicked on the URL quickly enough, it's possible they could start browsing in your current session - maybe even post replies as you (though I don't know whether additional elements are used for validation, particularly your IP address).
The bigger problem is that clicking a link containing an SID can lead to various session related weirdness. If someone else clicks a link that contains an sid, it's not then possible to post a reply even if that user was logged in when they clicked the link - because the linked thread isn't brought up in their session. If a link is clicked that contains an sid, you can finish up inadvertently closing all windows in your main session - which can leave you with the situation where the forum software has already updated the time of your last visit in its database and you can't then go back to view threads since your last visit that you hadn't read.
Indeed, if the original poster clicks a link containing an sid element, they'll probably find that the session has expired.
(writing for the purposes of education - this is definitely not a complaint because I'm glad that people are posting links between threads; it makes the forums much more usable)
Howarduk
PostPosted: Wed Jan 14, 2004 10:52 am    Post subject: Reply with quote
Hi David
Hadnt realised it could do that much damage. Was just pleased that I could answer the question. Anyway, will remember that next time I have occasion to post a link.
Howard
DavidW
PostPosted: Wed Jan 14, 2004 5:18 pm    Post subject: Reply with quote
Thanks for taking my comment in the spirit in which it is meant. Posting links isn't the easiest thing to learn how to do - and I'm grateful when people do post links, as it saves a lot of searching around to find information.
Keep on using the forums - it's only because we ask and answer questions that our knowledge grows.
SlimboyFat
PostPosted: Sun Feb 01, 2004 11:53 pm    Post subject: Reply with quote
An even neater solution would be the "URL" code on the Post A Reply page.
So it would look like this...
Check out THIS THREAD
It's a bit hard to explain here as the forums will turn my examples into links, but here goes...
A squared "open Bracket" [
url=
The full web address including the http:// (missing the sid bit as mentioned above.
A squared "close Bracket" ]
The text you want to appear
The click the "Close Tags" button
Hope this helps
DavidW
PostPosted: Sun Feb 08, 2004 8:18 am    Post subject: Reply with quote
Agreed!
I usually 'hide' the URLs of links I post in that way unless there's a particular reason why I want the address itself to be visible.
20.094 (28 Sep 22)
Terms & Privacy
