Pocket GPS World :: View topic - 910 wobbly mount fix
pepperm
PostPosted: Mon Aug 14, 2006 2:24 pm    Post subject: 910 wobbly mount fix Reply with quote
:D
I was so fed up with my 910 mount wabble and droop that when TomTom sent me an ineffective replacement I set about the old mount with a drill and a 6mm tap and think I have got a workable solution that fixes the droop and a certain amount of wobble.
I dismantled the mount which involved clipping off the cover and removing the screen tightening pin (for want of a better description) then drilled 2 5mm holes through the rubber ball socket. I then threaded the holes and made some short screws to fit. Now once aligned on the screen I just tighten the screws and "bingo" no droop.
Here are some photos
Sorry for using the robosavvy forum to host the pictures but I couldn't fathom how to upload the images here.
Mark
PostPosted: Mon Aug 14, 2006 5:26 pm    Post subject: Reply with quote
Thanks for the interesting "mod"
You cannot upload pictures to our site, so the way you did it is the only right way.
Pedro2NR
PostPosted: Wed Aug 16, 2006 5:23 am    Post subject: Reply with quote
Great Mod! You should also post this at YOUR NAV
My mount doesn't droop, but it does wobble
RDS
PostPosted: Wed Aug 16, 2006 8:06 am    Post subject: Reply with quote
Just a thought but could it be that a certain of amount of wobble is preferable to a rock steady mount ?
A bit of movement or wobble will act as a sort of shock absorber while if the mounting is too firm or solid all shocks will be transmitted through to the GPS, which may not be good for future reliability.
PostPosted: Wed Aug 16, 2006 8:35 pm    Post subject: Reply with quote
yes and no. The ideal solution is in sync with the movement of your eyes, so that you get an illusion of a steady position relative to yours.
So it should be as wobbly as your seat cusion vertically, but should be sturdy horizontally.
PostPosted: Thu Aug 17, 2006 4:04 pm    Post subject: Reply with quote
Now I'm imagining some amazing Heath Robinson contraption to synchronise screen with eye position! Laughing
PostPosted: Thu Aug 17, 2006 6:29 pm    Post subject: Reply with quote
I was more thinking about a Wallace and Gromit theme...
fatmanscoop
PostPosted: Thu Aug 17, 2006 7:36 pm    Post subject: Reply with quote
because of this stupid mount i can no longer play MP3's on my 910 as it wobbles around far to much and wont connect properly....i have a new mount on order from TomTom but how long before that one gives up the ghost. Such a great piece of kit with such a Censored mount Pistol Shoot Out
Garmin xt mobile
Nokia N96
Liverpool F.C rocks
22.043 (17 Apr 24)
