Pocket GPS World :: View topic - GATSO for NAVMAN
GATSO for NAVMAN
juleigh
PostPosted: Sun Jul 23, 2006 12:24 pm    Post subject: GATSO for NAVMAN Reply with quote
I use NAVMAN ICN 650 I just (today)downloaded the latest database including SPEC, Mobile etc. I have gone into POI on NAVMAN and quite happily can import the asc with bmp files for spec, mobile, redlight and temp but every time I try to do the GATSO it says Internal Navman Error.
Can anyone help me please?
Juleigh
tonys66
PostPosted: Sun Jul 23, 2006 12:35 pm    Post subject: Reply with quote
Can't help, I'm afraid, but you might like to watch this thread were mrcarpcatcher has a similar problem:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=43333&highlight=
inspector180
PostPosted: Sun Jul 23, 2006 5:30 pm    Post subject: Reply with quote
I have been trying to do the same today and get the same result on my Navman icn 630 - OK with mobiles, redlights etc, but internal Navman error on GATSOs. Hope somebody has the answer Smile
Tim Buxton
PostPosted: Sun Jul 23, 2006 5:45 pm    Post subject: Reply with quote
OK, as a workaround, can you open the gatso.asc file in Notepad. Search for GATSO:3542@50 and delete the whole line, then save the file again. I have had it confirmed that this will work on an iCN520, and have transferred it myself onto an iCN550 which would not take the original file. My iCN530 accepted the original file so perhaps SmartST2006 devices are unaffected.
This camera is in the Republic of Ireland so will have minimal impact on what is meant to be a UK database. Perhaps this camera needs to by moved into the European database.
Tim
inspector180
PostPosted: Sun Jul 23, 2006 5:48 pm    Post subject: Reply with quote
OK, I'll try that
inspector180
PostPosted: Sun Jul 23, 2006 5:55 pm    Post subject: Reply with quote
That's fixed it.
Thanks very much for your fast help.
juleigh
PostPosted: Sun Jul 23, 2006 6:54 pm    Post subject: Thanks Reply with quote
That certainly fixed it. I am impressed with your service, thank you.
Juleigh
captureboy
PostPosted: Tue Jul 25, 2006 3:12 pm    Post subject: Reply with quote
Why would removing this one camera location solve the problem, is there a limit to the amount of cameras you can have in one file?
Tim Buxton
PostPosted: Tue Jul 25, 2006 7:10 pm    Post subject: Reply with quote
Why, we don't know. It has happened once before with one of the speedzoned files and it was fixed in a similar fashion. There may be a limit to the number of cameras in one file but we haven't reached it with the Gatso file. After all, we have over 9000 in the single file.
Tim
captureboy
PostPosted: Tue Jul 25, 2006 7:37 pm    Post subject: Reply with quote
Could the problem be caused by the camera location, that is removed to fix the fault, is not on a map installed on the users sat nav.
I understand the camera location in this latest instance was in the Repuplic of Ireland, this would not normally be a map installed by default on the ICN 510.
mrcarpcatcher
PostPosted: Tue Jul 25, 2006 8:37 pm    Post subject: Reply with quote
No. I have the cameras in Belguim and the euro cameras installed but only put the maps on when i go across the channel as my memory card is to small to have England and France on at the same time. Mine works fine now Tim has said remove the said Irish camera.
Tim Buxton
PostPosted: Tue Jul 25, 2006 9:13 pm    Post subject: Reply with quote
No, I don't think so. The original file went onto a 530 (SmartST2006, no Irish maps) but wouldn't go onto a 550 (SmartST2005 Rel2, all EU maps on internal hard drive). To me, this makes it a pre-SmartST2006 issue.
I still have no idea what exactly causes the problem, though.
As I understand it, the downoad has been updated anyway, making the problem moot. Or is that not the case?
Tim
dizzyfergy
PostPosted: Sat Jul 29, 2006 1:09 pm    Post subject: Reply with quote
The updated file can not have been loaded ,as yesterday i had the same problem and the quick fix cured it . It seems the faulty camera location is still in the database.
Tim Buxton
PostPosted: Mon Jul 31, 2006 10:35 am    Post subject: Reply with quote
I've been assured that the new DB has been uploaded and it's possible that you're downloading a cached version.
Tim
jonnie
PostPosted: Thu Aug 03, 2006 11:18 pm    Post subject: Reply with quote
I had the same problem with my Navman 520. Undertook the fix suggested above - and all now loaded in and working correctly. I downloaded the files this morning - so not sure why the problem remains with the GATSO file. Anyway - all working now!! :D
22.043 (17 Apr 24)
