Newsletter
Pocket GPS World :: View topic - Ipaq 2210 External Power Supply
Rosco
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Ipaq 2210 External Power Supply Reply with quote
If its any help I have the Arkon powered PDA mount and 2210 combination and the 38xx/39xx usb lead that came with it connects and works ok with my 2210.
My only advice would be not to buy this mount bundle from Expansys - I was missing several items from the "bundle" and they still haven`t sent them all to me after nearly two weeks!
longwori
Hi, I am thinking of buying a new Ipaq (2210/2215) and was wondering if the power supply connector that came with my Arkon CM506 mount would fit and power it. The connector is meant to power iPAQ 38/3900 series. Does anyone know if its the same type of connector, same wiring and voltage as the 38/3900's?
Thanks, Ian.
TomTom Go 520, HTC Wildfire with CoPilot Live Premium UK & CoPilot Live Standard USA
DavidW
The 221x has an identical base connector as 3800/3900/5000 series iPAQs - though the physical size of the main unit is different meaning that some cradles do not fit physically.
ap
PostPosted: Thu Sep 25, 2003 9:20 pm    Post subject: Reply with quote
On the same topic I have purchased a bluetooth GPS BT - 308 to use with my 2210 which came with a car charger. There is a lead which will fit into the 2210 but I'm not sure if it is suitable. The adapter rating is 5v 1.2 amps and positive pole centre. Any help apprecited.
PostPosted: Thu Sep 25, 2003 9:29 pm    Post subject: Reply with quote
Yes the charger for the BT308 will work OK charging the 2210.
You can buy a splitter cable from www.pc-mobile.net which will connect the the car charger at one end and the iPaq and BTGPS at the other and charge both at the same time.
Editor, PocketGPSWorld.com
20.052 (11 May 22)
