Pocket GPS World :: View topic - Getting TomTom5 to work on my PDA
foley
PostPosted: Mon Feb 13, 2006 10:31 pm    Post subject: Getting TomTom5 to work on my PDA Reply with quote
Hi Guys,
I'm new on here, treat me gently :D
I've got an Orange SPV M500 loaded with TomTom5 and a Holox BT 321 GPS receiver. The GPS receiver appears to be working ok and is flashing to indicate that it's locked on ok. The PDA is picking up the bluetooth signal from the gps receiver but TT is not recognising it. I've tried to manually configure the GPS receiver to TT but the TT sotware doesn't give me a bluetooth serial port option, only infra red or serial cable.
Any ideas?
dksbbs
PostPosted: Tue Feb 14, 2006 2:42 am    Post subject: Reply with quote
Try the following
Go to
Preferences
GPS Status
Configure
Select Other NMEA GPS baud rate 38400
Bluetooth Serial Port Com6
Works on my M1000
foley
PostPosted: Tue Feb 14, 2006 10:48 am    Post subject: Reply with quote
Thx for the reply Dave.
When I get to the last bit, selecting a COM port, I only get the option of infra red or serial cable ports and no COM 6.
peterc10
PostPosted: Tue Feb 14, 2006 8:09 pm    Post subject: Reply with quote
Choose one of the serial cable ports (I know you have BT but don't forget this is tom tom logic at work) and try it. If that one does not work try the other. You may also need to experiment with the BAUD settings - generally better to start low and work up.
Peter
HTC Sensation
Copilot for USA
Bury CC9060 bluetooth car kit & Brodit mount
alix776
PostPosted: Tue Feb 14, 2006 8:40 pm    Post subject: Reply with quote
might be a silly question but have yo paired the receiver you need to select other bt gps then com6
first on the pda go to the bluetooth manager then select new device/ partnership then search for the gps and then select thegps put in a passkey of 0000 the start tomtom go to the gps menu select other bt gps then com6 baud rate 38400 give it a second and see if it works
if that doesn't work then reinstall the tomtom navigator application after removing it first
device Lumia 950 xl
foley
PostPosted: Wed Feb 15, 2006 12:30 pm    Post subject: Reply with quote
Thx for the help guys.
Yes I've paired the PDA to the GPS.
I don't get the option of COM6 on my PDA, I don't get any bluetooth options.
I should be geting these options:
GPS is connected to:
USB Cable
Serial cable on SP2
COM3
Native IR
Serial cable on COM1
Bluetooth Serial Port ....
But the only options I get are these:
Infrared Port
COM9
COM2
Serial Cable on COM1
COM4
COM5
alix776
PostPosted: Wed Feb 15, 2006 1:35 pm    Post subject: Reply with quote
try removing tomtom from the pda soft reset then try reinstalling it
device Lumia 950 xl
foley
PostPosted: Wed Feb 15, 2006 1:41 pm    Post subject: Reply with quote
Will give it a go this afternoon.
Mike
foley
PostPosted: Wed Feb 15, 2006 8:13 pm    Post subject: Reply with quote
Tried removing TT from the PDA, soft reset and reinstall but stil not working. When installing this time I noticed this message -
The program you have installed may not display properly because it was designed for a previous version of Windows Mobile Software.
Could this be the root of my problem?
peterc10
PostPosted: Thu Feb 16, 2006 12:46 am    Post subject: Reply with quote
Is your PDA running windows mobile 2005? If so you need to upgrade to latest version of TT - free downlaod from the Tom Tom site.
Peter
HTC Sensation
Copilot for USA
foley
PostPosted: Sun Feb 19, 2006 7:51 pm    Post subject: Reply with quote
Still no joy.
I'm running Windows 2003.
alix776
PostPosted: Sun Feb 19, 2006 9:24 pm    Post subject: Reply with quote
are you sure its tomtom5 as tt5 will still run on 2002 machine you shouldnt be getting that message
device Lumia 950 xl
pointything
PostPosted: Mon Feb 20, 2006 9:26 am    Post subject: Reply with quote
Hi There,
I had the same problem. Have a look at this great guide over at XDA-Devlopers.com http://forum.xda-developers.com/viewtopic.php?t=28386
(The Jasjar is identical to the M5000)
Pointy
PostPosted: Mon Feb 20, 2006 9:40 am    Post subject: Reply with quote
Just before you go following the above link bear in mind what device you have (SPV M500), the link above is for a different unit (SPV M5000), so the advice there might not be too much use - Mike
pointything
PostPosted: Mon Feb 20, 2006 10:14 am    Post subject: Reply with quote
Oooops, very sorry. I should not read forums early in the morning. I thought this was about the M5000
Pointy
22.044 (24 Apr 24)
