Pocket GPS World :: View topic - [i3] gps switched off
john59
PostPosted: Sat Jan 21, 2006 7:53 pm    Post subject: [i3] gps switched off Reply with quote
Hello guys and gals Laughing
I have just today bought 2 i3s @ £179 for both from kwiksave, I seem to be having a problem with the GPS. When the GPS is turned on in the settings it later turns off (within mins ) so I then turn it back on or normal as it says, then go back to the map screen it then says on the screen (aquiring satallites) but mins later it says on are you indoors too wich I answer YES the screen changes to the map and it now says GPS IS OFF.
Is it simply because I am at my pc indoors at the moment.
Regards.
John
alan_t
PostPosted: Sat Jan 21, 2006 7:57 pm    Post subject: Reply with quote
yes.
ride4smilesjonny
PostPosted: Sat Jan 21, 2006 8:04 pm    Post subject: Reply with quote
8O
tomthompson
PostPosted: Sat Jan 21, 2006 10:38 pm    Post subject: Reply with quote
When you first use a gps it can take upto 45 minutes to get a fix allow for that . Afterwards it is a lot faster
If your indoors it will allow you to view maps without a fix and will turn off the gps.
You need to start it off in the car and with a good view of the sky.
From then on its easy peasy.
CoPilot
Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
I keep on learning but they invent new things faster ,How do I keep up ?
22.034 (27 Mar 24)
