Pocket GPS World :: View topic - Holux GM 210 Vs Holux GR 213
nishan
PostPosted: Mon Nov 21, 2005 6:04 pm    Post subject: Holux GM 210 Vs Holux GR 213 Reply with quote
I wanna know which one is the best?
thanks
uffe73
PostPosted: Mon Nov 21, 2005 9:16 pm    Post subject: Re: Holux GM 210 Vs Holux GR 213 Reply with quote
thanks
I have no experience of the GM 210, but I can at least advice you not to buy the GR-213. Read this thread and you'll get an idea why. It will work fine for you for a couple of weeks; after that the Time To First Fix will increase and eventually make it useless. This will at least happen if you don't get a permanent power supply.
Ulf
TomTom GO720T: App ver 8.351(9982/090518), OS:315187, GPS v1.20, Boot 5.5120
TT RDS-TMC: 4V00.013
Maps: Scandinavia v840.2562, Western_Europe v715.1703
Garmin GPSMap 60CSx (SW ver. 3.70)
nishan
PostPosted: Tue Nov 22, 2005 4:28 pm    Post subject: Reply with quote
thanks
MikeProcter
PostPosted: Thu Nov 24, 2005 12:23 am    Post subject: Re: Holux GM 210 Vs Holux GR 213 Reply with quote
uffe73 wrote:
thanks
Ulf
My GR-213 is still working ok after 2 1/2 months of constant use & 6000 miles.
Mike :D
Skoda Columbus and for emergencies: TomTom + iPhone 4 & TomTom car kit
uffe73
PostPosted: Thu Nov 24, 2005 8:51 am    Post subject: Re: Holux GM 210 Vs Holux GR 213 Reply with quote
Mike :D
Lucky you! Confused
I guess you have it permanently hardwired to your car battery then. That makes the difference.
/Ulf
MikeProcter
PostPosted: Sun Nov 27, 2005 12:54 am    Post subject: Re: Holux GM 210 Vs Holux GR 213 Reply with quote
uffe73 wrote:
Lucky you! Confused
/Ulf
No, its wired to the ignition, but I may hardwire to the battery so that I have no problems whatsoever. Just need to find a permanent live feed.
Mike
ignatius
PostPosted: Thu Dec 22, 2005 2:01 pm    Post subject: Re: Holux GM 210 Vs Holux GR 213 Reply with quote
MikeProcter wrote:
uffe73 wrote:
Lucky you! Confused
/Ulf
Mike
Use your Radio-backup cable. Usually the yellow one.
I cant get my 213 to work with TTN5(I've got an x51v with mobile5). You guys got any ideas? GPSViewer, GPSTuner and Winfast Navigator all work fine.
MikeProcter
PostPosted: Thu Dec 22, 2005 5:30 pm    Post subject: Re: Holux GM 210 Vs Holux GR 213 Reply with quote
Thanks. Not sure if that will be the case with my BMW as the radio dosen't work without the ignition on. I'II have a look over christmas break.
As for your GR-213 not working, try configuring it as a tom tom wired device. failing that try configuring it as another nmea device, 4800 baud.
If you have already tried this, then over to the darkside - the WM/PPC guys for help.
I seem to be the only enlightened one using Palm OS!!!!!!
ignatius
PostPosted: Thu Dec 22, 2005 7:27 pm    Post subject: Reply with quote
The yellow backup cable is for the radio-memory. Every car has one
As for my GPS device....
I've installed navigon, it works fine. Navigon detected my receiver with automatic detection. I had a fix in no-time. It's TTN5 that's givin' problems...
Can anyone else help me??? PLEASE!!?? Rolling Eyes
ignatius
PostPosted: Thu Dec 22, 2005 9:07 pm    Post subject: Reply with quote
Never mind, I've got it workin' baby 8)
The solution came from a nother thread. I've read about a program calls GPSGate. Downloaded it, installed it.. and it worked!! After that, I bought it :P
Now I'm very happy!!!
MikeProcter
PostPosted: Fri Dec 23, 2005 3:23 pm    Post subject: Reply with quote
Thanks. found it. now my GR-213 is permanently hard wired to the battery.
Glad to hear you sorted TTN.
Robin2
PostPosted: Mon Dec 26, 2005 1:40 am    Post subject: Reply with quote
Nobody has said anything about the GM210. I have used one for over 2 years, and it hasn't put a foot wrong yet. Time to a cold fix seems a little longer than it used to be, but the internal battery which retains the satellite data is possibly getting a little tired now. I have just invested in a GPSlim bluetooth for the improved sensitivity that Sirf 3 brings, but the GM210 is still going strong
Robin
TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used
22.044 (24 Apr 24)
