Pocket GPS World :: View topic - GPS Assist with Pocket PC 2003
cuk0724
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: GPS Assist with Pocket PC 2003 Reply with quote
Just found this forum and this message. If have an iPAQ 2210 and if I am running GPS and TomTom with my Bluetooth GPS and turn the ipaq off you can't re-start it with the on/off button, only by a soft reset. On the HP US forum is listed the same problem, and the answer looks like a ROM problem in the ipaq. No answer as to yet on a fix.
Also when I'm running GPS Edit if I tap on the contacts button I get an error, Error "Application Error. An error was encountered while running this program: Object required: `polApp`" I then tap OK, the rest of the programme works OK but the contacts button becomes greyed out, and I can no longer use the point to point screen. Also any changes that are made to setting are not saved.
Does anyone else get this problem?
DocEvil
I've just bought an IPAQ 2210 and loaded TomTom Navigator 2 (v2.24 & GPS Status 2.06) on it. I'm using the Socket Bluetooth GPS. In order to use GPS Assist the pocket PC requires Embedded Visual Basic Runtime for Pocket PC 2003 which I downloaded from Microsoft. When I run GPS Assist and turn off the IPAQ during navigation (Which works OK when I used my 3970) I can only get the IPAQ 2210 to power back on via the hard reset button. Has anyone else had a similar problem?
I haven't tried GPS Assist, but another app Universal Converter wanted the Embedded VB Runtimes for me, but I couldn't get them installed.
The 2210's are starting to exhibit hanging for me, especially where you can either switch it on and it doesn't light up the screen (you need to soft reset), or you can pull down the start menu and the whole iPAQ freezes. I'm starting to believe this maybe application issues, I use Icbar, and Mike does too and he's experiencing the same problems, so we're unsure if it's a hardware or software issue.
Are you running Icbar or any other task manager ?
DocEvil
Hi Dave
Thankyou for the quick reply. I'm not using a task manager on my HP2210. The only software loaded is TTN2, GPS Assist & eVBR.
I installed the eVBR by copying the downloaded file (msvbppc.armv4.cab) to the SD card on my IPAQ via activeSync, locating the file via the IPAQ's explorer and clicking on it.
Regards
Paul
DocEvil
Hi Dave
I would also like to add that the HP2210 will power back up if I only have TTN2 running. The problem only occurs if I have TTN2 and GPS Assist loaded. Could this be due to GPS assist being compiled for PPC 2002?
DavidW
I've come across some vague mention of problems with the current eVB runtime for Pocket PC 2003 in microsoft.public.pocketpc - but nothing specific, I'm afraid.
I think this could be a Microsoft problem. Maybe it's worth looking at, or even asking a question in, microsoft.public.pocketpc about whether others are having problems with the eVB runtime on Pocket PC 2003.
bins
Read about this issue somewhere in the newsgroups.
Should be rather an iPAQ 2220 issue and an update should solve the problem.
Solution to the freezing was finally found in the POI's.
If I recall well, if you save them in a colordepth less (16 bit or so rather then 32 bit) the problem of freezing should be solved...
I don't personally have the 2220 nor the above experience, but thought to share it. Good luck!
21.014 (25 Jan 23)
