Dave Frequent Visitor
Posted: Sat Nov 06, 2004 4:07 pm Post subject: Adding Safety Camera Support to Navman Products |
Since the October release of the Safety Cameras, instructions have now changed for Navman users running V3 software which includes the V3 software itself (not yet released), iCN510, iCN635 and iCN650.
These instructions can be found here. |
AlfieB Regular Visitor
Posted: Sat Nov 06, 2004 5:01 pm Post subject: |
I see in your first paragraph, that you specifically exclude the iCN620/630 from this this procedure. I am aware that the new V3 software will not run on the iCN620 but why did you include the iCN630 as well
Was it because the V3 software package is not yet available
Regards
alfieB _________________ Why ask me ?, I'm lost!
Navman iCN630
Navman N60i
Navman Mio S505
Navman Mio Spirit 695 LM
Mio Spirit 7670 LM Truck |
Posted: Sun Nov 07, 2004 8:47 am Post subject: |
Exactly. |
STUD00 Occasional Visitor
Posted: Sat Mar 26, 2005 11:51 am Post subject: Re: Adding Safety Camera Support to Navman Products |
Dave wrote: | Since the October release of the Safety Cameras, instructions have now changed for Navman users running V3 software which includes the V3 software itself (not yet released), iCN510, iCN635 and iCN650.
hi
i have been trying to click on the link you have place in the forum but all i'm getting is a blank page i got a NAvman ICN 610 V3 i have updated it with SP1 from navman but would like to know if there are any other update for it and would also like to add the Speed camrea update to it
thanks |
Posted: Sat Mar 26, 2005 2:16 pm Post subject: |
We've been experiencing high levels of traffic. This has now died down to normal levels so try again you should be able to get through now. |
Quinny1 Lifetime Member
Joined: Mar 29, 2005 Posts: 202 Location: Ossett.West Yorkshire.UK.
Posted: Thu Mar 31, 2005 4:50 pm Post subject: |
Why does the database not recognise which direction you are travelling,because the warning tone on my sat nav goes off,no matter which way I'm travelling? |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Thu Mar 31, 2005 5:49 pm Post subject: |
It's not the fault of the database, rather it is because the Proximity Alert function built into V3 of SmartST PRO is based on giving the warning of any specified Custom POI within a given radius. You will get alerts for Custom POIs on parallel roads, for POIs on roads going under or over the road you are travelling on, etc..
Also, bear in mind that many cameras are rotatable. The database, if it acted on a directional basis, would have to be updated every time one of these cameras was spun around to face in the other direction.
I believe the TT GO has a tickbox to only warn of POIs on the current route. This is something which has been suggested to Navman as an option; hopefully they'll take it up. _________________ Tim |
Posted: Thu Mar 31, 2005 6:22 pm Post subject: |
Thanks for that Tim,clear as mud now. |
robertn Frequent Visitor
Posted: Fri Apr 01, 2005 12:52 am Post subject: |
I use the iCN even without a route bacause of the $peed Cam alert - The tick box option would not be very useful to me
I would rather have at alert if you are on the same road as the camera, but then, what happens when a camera is near an intersection? When I think about it, I think Navman has it pretty right. If I know there is a camera somewhere close, I can look out for it or slow down, rather than expecting the computer to drive my car for me. |
AdamHoyle Occasional Visitor
Posted: Thu Aug 11, 2005 10:03 pm Post subject: |
Just tried to load the speed cameras into my iCN650, difficult or what!
Incorrect file formats, No POIs on input file. The file doesn't look anything like the instructions!
Gave up after nearly 6 hours of changing from CSV to Excel, to Notepad, refromatting columns, adding commas, changing columns from Longitude to Latitude etc et c.
Sorry, I know it is me, but after 20 of using computers from the ZX81 onwards, I give up!
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Thu Aug 11, 2005 10:33 pm Post subject: |
AdamHoyle wrote: | Hi
Are you using the correct CSV files? You should be using those in the Other Folder.
Notepad is the only really safe way to edit the CSV file. You can't accidently save it in a different format. _________________ Richard
Andycambs Regular Visitor
Posted: Tue Dec 20, 2005 5:23 am Post subject: |
Get it quick before it's charged for.... |
Steve-on-A34 Occasional Visitor
Posted: Fri Feb 24, 2006 7:13 pm Post subject: Problems Loading on Navman? |
The file structures supplied do NOT lend themselves to easy uploading to Navman devices. The supplied instructions are actually not 100% correct so I’m not surprised you had problems
I have written a SED script I run over the supplied file structures that fixes it. SED is a UNIX editor but a windows version is available free from various websites to download.
If anyone wants my script then let me know and I’ll either post it as a message to copy (it’s only 23 lines) or send you a copy. It takes seconds to run and makes life so much easier to install on the Navman.
Mind you if they are going to charge for the files, there really should be a directory in the right format for all the supported platforms in the download. |
Posted: Fri Feb 24, 2006 7:30 pm Post subject: Re: Problems Loading on Navman? |
Steve-on-A34 wrote: | The file structures supplied do NOT lend themselves to easy uploading to Navman devices. The supplied instructions are actually not 100% correct so I’m not surprised you had problem
When I'm replying to a two month old post, I like to check that what I'm writing is accurate. As far as uploading to Navman devices is concerned, the .asc files require no editing. I'd say they lend themselves to VERY easy uploading to suitable Navman devices. _________________ Tim |
Posted: Sat Feb 25, 2006 12:32 pm Post subject: |
Accepted the post was old, but no one else seemed to have put there head above the parapet and replied. I have checked the asc files and the comments still stand. Having the file as an asc only means the first line is already commented out. My gripe revolves more around the structure of the lines and file naming. For reasons best known to Navman, it does not like the ‘@’ character so a line such as ‘-2.08936,53.50270,"GATSO:3@20"’ when imported in to the Navman POI editor becomes “20@53.50270, -2.08936, GATSO:3@20”. Sometimes you can get away with it, other times the system gives odd errors. In Navman terms the ‘@20’ adds no value, so I remove it from the lines giving a cleaner import. If you try and edit it in the POI editor you can’t as it says ‘20@53.50270 is not a valid floating point value’, so you have to change it in notepad. Next for some strange reason you will have to ask Navman, it likes 6 decimal places, not the 5 supplied. I simply pad each entry with a zero and now the POI editor is more than happy with the file. Next, Navman only supports 8 character file names. Whilst I understand why you call the files the way you do, it make life just that bit more complex for Navman entries. So I rename the files from for example pocketgps_uk_gatso_20.asc to gatso_20.asc. The import utility to the device now automatically gets a good name saving many mishaps when loading several files in to the device. Finally I copy some relevant images to the same directory and rename along the way so that it is only take a few clicks to get a matching image to go with the file. Now don’t get me wrong, I think the database is excellent, and have used it for a long time now (only just joined the forums though), but creating a folder for Navmans with these changes would make life so much easier.
Please accept this as a constructive criticism, not a knock at an excellent service that I will subscribe to. |
