Pocket GPS World :: View topic - Bluetooth headset and BT GPS
jaybeetoo
PostPosted: Wed Oct 06, 2004 7:52 pm    Post subject: Bluetooth headset and BT GPS Reply with quote
I have a bluetooth headset for my mobile phone.
Would I be correct in thinking I can use the BT GPS or the BT headset but not both at the same same with an Orange SPV C500?
PostPosted: Wed Oct 06, 2004 8:09 pm    Post subject: Reply with quote
You 'should' be able to use both. I have an E200 and had problems with a cheap BT Headset but having replaced it with a better one I can use BT GPS and BT Headset at the same time.
I don't have a C500 so can't personally confirm this is the case here but Dave has and may be able to confirm this.
stuartm
PostPosted: Wed Oct 06, 2004 8:23 pm    Post subject: Reply with quote
That's the setup I've got and can confirm that you can use a bluetooth headset and the CoPilot GPS on an SPV C500 at the same time.
stuartm
PostPosted: Wed Oct 06, 2004 8:27 pm    Post subject: Reply with quote
PS. Headset is a Nokia HDW-2
fozzie63
PostPosted: Thu Oct 07, 2004 7:19 pm    Post subject: Reply with quote
I use Fortuna BT ClipOn GPS and Jabra BT 250 headset at the same time on my C500.
jaybeetoo
PostPosted: Fri Oct 08, 2004 8:40 am    Post subject: Reply with quote
Thank you for the prompt and helpful replies.
seancraig
PostPosted: Thu Nov 04, 2004 7:25 pm    Post subject: Reply with quote
@fozzie Can you use voicedial ok with your BT250 ok
I have a Fortuna BT clip-on / C500 / BT200 and am having problems getting the voicedial to work...
PostPosted: Thu Nov 04, 2004 7:36 pm    Post subject: Reply with quote
I din't think voice dial was available on the E200 Confused
seancraig
PostPosted: Thu Nov 04, 2004 8:05 pm    Post subject: Reply with quote
22.034 (27 Mar 24)
