Pocket GPS World :: View topic - No satellite lock after install SP1
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navman Handhelds
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: No satellite lock after install SP1 Reply with quote
Following NavMan's instructions and running the file they sent worked fine. Problems solved, obtained a fix within a few seconds.
Dominic Davies
You guys are the best!
Following this I've managed to sort my 3400 out too! Geez, when will NAVMAN deliver a product worth using?
I'd sell mine but think I'd be selling something bad to someone and have my ethics and conscience to consider!
Leenig
Thank god for that Richard sometimes I feel so thick its nice to see you had the guts to hold your hand up as well Smile
What I really like about this forum is other members do reply in laymans terms if asked and dont attack someone for what may appear to be a dumb question.
Lee
Quote: Sorry but Im sure other may be asking the same questions:
Where is the file copied to on the IPAQ anywhere or into the Navman folder?
GPS View is that the GPS Status windows?
Same two questions I asked NavMan when they sent me the file!
Correct, doesn't matter where, personally I put it on root and it worked okay.
Royalty
Lee, GPS View is the program you copy to the iPAQ contained in the zip file.
I'm assuming you can put it anywhere on the iPAQ as it's just a run-once program that installs it's own changes?
Leenig
Dave ,
The rest appears striaght forward.
Lee
Copy the above file to your iPAQ
Attach your GPS sleeve
Run GPS View
Tap COMMS | START (Detect)
Tap COMMANDS | SET MSG RATE
Tap GGA drop down menu and scroll to you get to RMC
Select RMC
Set the number on the right to 2
Exit GPS View
Soft reset your iPAQ (very important!)
Now try SmartST Pro, the satellite acquisition problem should now be fixed.
Check out this message thread for full details.
Tim Buxton
Where dat den?
Sure, it's there now.
Royalty
Just wondering if it's possible to have this file uploaded on this site under downloads maybe (Dave?)
I installed SP1 at lunch time and now my NavMan 3400 won't get a satellite lock! I've left it in the car for the last hour and tried re-setting the iPAQ several times.
After starting SmartST it just displays Waiting for GPS, then if I select the GPS status display it shows 7 satellites, all the indicators being yellow with the circle being green, but no GPS position is shown. Seems strange as it is certainly picking up satellites. I've left it in both screens for at least 15 minutes each before trying to reset the unit.
Any ideas anyone? At the moment it looks completely screwed. Nice to see SP1 was tested well. I've never had any problems with the unit before.
gambitgander
This would be right. By resetting teh RMC message rate, you should now be able to obtain stable GPS fix.
Who's Your Daddy?
This is the resonse I've just got back from NavMan. I don't have the iPAQ with me so can't try it until tonight.
Please copy the attached file to your iPAQ. Attach your GPS sleeve. Run GPS
View. Tap on Comms -> start (detect)
Then tap on Commands -> set msg rate. Tap the GGA drop down menu and scroll
down until you get to RMC. Select RMC and set the number to the right of it
to 2. Soft reset your iPAQ. Very Important!
gambitgander
The non-fix is attributed to the RMC messages not being turned on. Before a hard reset and heart-ache, contact the Navman support team for a resolution.
Who's Your Daddy?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navman Handhelds All times are GMT + 1 Hour
20.115 (30 Nov 22)
Terms & Privacy
