Pocket GPS World :: View topic - BT GPS - heated rear windscreens
proctog
PostPosted: Mon Nov 01, 2004 11:13 am    Post subject: BT GPS - heated rear windscreens Reply with quote
I considering buying a Bluetooth GPS for use in the car (with a Palm Tungsten T3) and am looking at the options for where to site it. Somewhere on the top of the dashboard at the front is the obvious choice, but it might be less intrusive to have it on the rear parcel shelf.
Is this feasible? I know there can be problems with cars with athermic/heated windscreens causing GPS reception problems (my car has a "normal" windscreen) but is the same true of rear windscreens? The embedded heating wires run horizontally and are about 2cm apart. The heated windscreens I've seen seem to have a very fine mesh of wires.
Does anyone here use a BT GPS on the rear shelf?
TIA
Glenn.
tOpCaT
PostPosted: Tue Nov 02, 2004 2:42 pm    Post subject: Reply with quote
Hi Glenn,
I've got a BT GPS on the rear shelf of my Renault (not right now, but when I'm using it Smile ). It works fine.
I couldn't use it on the dashboard due to the bizarre metallic coating Renault put on their windscreens (which makes them look a crappy blue colour and seems to prevent GPS signals from getting through).
I hope this helps.
Tom
proctog
PostPosted: Tue Nov 02, 2004 2:52 pm    Post subject: Reply with quote
tOpCaT wrote:
Hi Glenn,
I hope this helps.
Tom
Thanks for the reply. The Renault coating must be a fairly recent "innovation" - I had a Megane Coupe up until about a year ago and my eMap worked OK when sitting on top of the dashboard.
Glenn.
22.043 (17 Apr 24)
