Pocket GPS World :: View topic - POIS
POIS
Coaster2
PostPosted: Mon Dec 27, 2021 8:49 pm    Post subject: POIS Reply with quote
Can anyone tell me how to remove points of interest from a Garmin Nuvi 65 please.
PostPosted: Tue Dec 28, 2021 5:17 am    Post subject: Reply with quote
Connect the unit to a PC and look in the POI folder.
Satnav:
Car Average MPG :
Coaster2
PostPosted: Tue Dec 28, 2021 10:19 am    Post subject: Reply with quote
Thank you. I'll try that. Worked a treat. Many thanks.
Coaster2
PostPosted: Thu Dec 30, 2021 3:20 pm    Post subject: Reply with quote
My mistake. All I managed to do was remove the speed cameras.
PostPosted: Thu Dec 30, 2021 4:01 pm    Post subject: Reply with quote
Yes, you do need to identify the correct file.
Satnav:
Car Average MPG :
PostPosted: Thu Dec 30, 2021 6:14 pm    Post subject: Reply with quote
Are you referring to the built in ones from Garmin or ones you have manually added?
Coaster2
PostPosted: Thu Dec 30, 2021 8:38 pm    Post subject: Reply with quote
I manually added them some time ago. I'm now fed up with seeing knives and forks all over the screen.
PostPosted: Fri Dec 31, 2021 6:16 am    Post subject: Reply with quote
Search the device for all .GPI files and post back what you find.
We can then compare notes as to what should and shouldn't be there as I've got no additional POI's.
No rush, I'm not back home till Sunday
Satnav:
Car Average MPG :
PostPosted: Fri Dec 31, 2021 7:27 am    Post subject: Reply with quote
Note Garmin will hoover up POI files from anywhere, not just in the POI folder, so do a global search for .gpi files. Having said that the issue appears to be that you have the Up ahead map layer checked, which is why you're seeing knives and forks etc everywhere. Uncheck it and they should disappear.
Coaster2
PostPosted: Fri Dec 31, 2021 10:09 am    Post subject: Reply with quote
Many thanks. I'll follow the advice given and report back.
Coaster2
PostPosted: Fri Dec 31, 2021 3:46 pm    Post subject: Reply with quote
Found one .gpi file 1.33 mbyte. Deleted it and when I checked the POI file it was empty. I won't be out in the car until tomorrow so I'll have a look and see what's happened then.
Coaster2
PostPosted: Sat Jan 01, 2022 11:43 am    Post subject: Reply with quote
Unfortunately all it did was to get rid of all the speed cameras. When I use the POI loader to load the speed cameras I get the message: ‘Congratulations you have successfully loaded 17671 POIs on your device.’
PostPosted: Sat Jan 01, 2022 12:05 pm    Post subject: Reply with quote
On a PC you should be able to the creation date, plus the filename will be the POILoader folder name so you can identify that one easily.
Satnav:
Car Average MPG :
Coaster2
PostPosted: Sat Jan 01, 2022 1:28 pm    Post subject: Reply with quote
I've tried everything now and the only way I seem to be able to get rid of the knives and forks is to lose the speed cameras as well. Looks like I'm going to have to live with it.
dales
PostPosted: Sun Jan 02, 2022 12:03 am    Post subject: Reply with quote
You should listen to sussamb, I think. Very Happy
On my Garmin 2599. I get icons for knives and forks (etc) on the screen from the (Foursquare) POIs which are effectively built into the map.
The way to hide them is as sussamb has said.
On my Garmin, I go into settings for Map & Vehicle ... Map Layers and uncheck Up Ahead and press Save.
Dales.
nuvi 2599LMT-D, oregon 700, basecamp, memory-map.
22.043 (17 Apr 24)
