Pocket GPS World :: View topic - Garmin CSV to GPX Converter
Goto page Previous  1, 2, 3 ... 65, 66, 67 ... 72, 73, 74  Next
keithmillar
PostPosted: Sun Oct 06, 2019 10:57 am    Post subject: Reply with quote
Can someone tell me what I've done wrong from the screenshots, please.
I've download from Kremmen link, set up my working folder, downloaded the latest zip file by following the instructions but when I try to unzip the following is what i'm getting.
The second screenshot is of my working folder
Keith
Garmin 3598LTM-D
Android CoPilot
Navigon 72 Plus Live
TTGO540
PostPosted: Sun Oct 06, 2019 11:08 am    Post subject: Reply with quote
Delete those 4 Excel marked files, they shouldn't be there.
Satnav:
Car Average MPG :
keithmillar
PostPosted: Sun Oct 06, 2019 11:47 am    Post subject: Reply with quote
Thank you.
Those 4 Excel files were part of the camera download from PGPSW. After I cleared the 4 Excel files, and then ran the software again it put the 4 Excel files back. The size of the file I downloaded was 2,120kb, if this helps
So I then went for another camera update download but the size was 208kb, and everything went well and have now updated my Garmin
Keith
Garmin 3598LTM-D
Android CoPilot
TTGO540
PostPosted: Sun Oct 06, 2019 2:56 pm    Post subject: Reply with quote
Spot on. You downloaded the wrong database in the first place. Very Happy
keithmillar
PostPosted: Sun Oct 06, 2019 3:19 pm    Post subject: Reply with quote
So what's the difference, beside the file size?
Keith
Garmin 3598LTM-D
Android CoPilot
TTGO540
PostPosted: Sun Oct 06, 2019 4:23 pm    Post subject: Reply with quote
Well, as I don't know which file you downloaded in the first place, I don't know.#
Suffice to say that the first one doesn't work so is obviously wrong and the second one works etc.
Can't work it out either.
The proper file is 208kb (as you have found)
Are you sure that the big one was not a re download of Kremmens program? No, it wasn't that. Kremmens is enormous.
PostPosted: Mon Oct 07, 2019 3:29 am    Post subject: Reply with quote
Is it Laughing Laughing
I have to check for duplicate files in all Working Folder directories and sub directories or duplication may occur.
If you use the download database link from within the Converter then you will always get the correct 'Garmin Speed Zoned' download.
Satnav:
Car Average MPG :
PostPosted: Sun Dec 29, 2019 11:40 am    Post subject: Reply with quote
I've had a small number of requests for help setting up the Converter.
Given that I will only have very limited access to my PC, and therefore TeamViewer access, I've created what I hope will help some get the Converter started.
In the download package are 2 new folders, both laballed 'Simple':
Let me know if there is anything missing to get you going. They aren't designed to fine tune the package but just to get you started with sound and icons that seem to be the most requested problem.
Satnav:
Car Average MPG :
Rick-uk
PostPosted: Wed Mar 04, 2020 10:45 pm    Post subject: Check Database Error - Windows 7 (64 bit) virtual machine Reply with quote
When I try to run the CSV/GPX converter on a Windows 7 virtual machine (Linux host) I receive the following error.
Clicking OK on the dialogue just closes the window with no chance to access settings etc
The VM has full internet access (although being W7 I am thinking of restricting it to LAN only soon)
It works fine on a W10 virtual machine using the same Linux Mint host (64 bit) but that is just so bloated, laggy and intrusive that I would rather not use it if possible.
I also tried installing it under WINE but that refuses to install .net services for me.
Any ideas please what needs to be done to rectify this or can I bypass the database check at startup.
Kind regards
Rick
https://share.octopus.energy/dense-raven-261
PostPosted: Thu Mar 05, 2020 6:25 am    Post subject: Reply with quote
The latest versions of .NET require TLS 1.2 to be the default protocol
TLS is a replacement of the Secure Sockets Layer protocol (SSL). It provides secure communications on the internet. It is used for web browsers and other applications that require data to be securely exchanged over a network such as an email, file transfers, VPN connection and voice over IP.
Windows 7 supports TLS 1.1 and TLS 1.2. But these protocol versions are not enabled on it by default. On Windows 8 and higher these protocol are enabled by default.
Follow this link for info to force Win7 to use TLS 1.2 :
https://manage.accuwebhosting.com/knowledgebase/3008/How-do-I-enable-TLS-12-on-Windows-7.html
Satnav:
Car Average MPG :
Rick-uk
PostPosted: Thu Mar 05, 2020 1:11 pm    Post subject: Reply with quote
Thanks, that sorted it. Thumbs Up
I had searched the error previously and the results I found had me adjusting windows features in settings to no avail.
Now just to figure out why my WINE will not install .net services Very Happy
PostPosted: Thu Mar 05, 2020 1:47 pm    Post subject: Reply with quote
Can't help you there as I'd never heard of it
Satnav:
Car Average MPG :
Rick-uk
PostPosted: Thu Mar 05, 2020 6:35 pm    Post subject: Reply with quote
It is just an alternative method for running Windows apps under Linux
PostPosted: Thu Mar 05, 2020 6:44 pm    Post subject: Reply with quote
Quite a few posts down it looks like it's been solved.
Scroll down to Sep 29 @ 2:15pm
https://forum.winehq.org/viewtopic.php?f=2&t=32869
Satnav:
Car Average MPG :
Rick-uk
PostPosted: Thu Mar 05, 2020 6:55 pm    Post subject: Reply with quote
Looks like I need to set aside a day for the process
Will read it all thanks
Page 66 of 74
22.043 (17 Apr 24)
