Newsletter
Pocket GPS World :: View topic - Kenwood Dnx series
Kenwood Dnx series
Speedcat1
PostPosted: Tue Nov 27, 2018 8:11 pm    Post subject: Kenwood Dnx series Reply with quote
YOUR SOFTWARE IS NOT SHOWING THE INFORMATION STATED, NO RED LIGHT CAMERAS DISPLAYED. NO AUDIO/ VOICE ALERTS. I have tried 4 times now trying to get this to work but still no joy..
Can anyone help?
The Kenwood is operating the Garmin Softwear
Followed all instructions. would not install Garmin POI vis SD card Had to use a memory stick..
Paying for a service I can't use..
cjay2412
PostPosted: Tue Nov 27, 2018 10:22 pm    Post subject: Reply with quote
you need to use Garmin poi loader to create the file this has to be placed on to a USB stick (sd card is for map updates only) in a folder Garmin /POI before you insert the USB stick in to the Garmin it has to be on the navigation home screen (where to /view map) then insert the USB stick and a popup appears click yes then job done. voice alerts can work on the Kenwood just follow the Garmin guide on this site.
csv to gpx converter is a good piece of software to configure the alerts to how you want them software downloads and guide available on this site.
PostPosted: Wed Nov 28, 2018 2:05 pm    Post subject: Reply with quote
For the audio you need to use the WAV files. Can you confirm you have sox.exe in the same folder as POILoader.exe
Also, have you extracted the files from the downloaded zip file?
And, finally, does POI Loader confirm that around 30,000 POIs have been loaded after it's run?
PostPosted: Wed Nov 28, 2018 10:07 pm    Post subject: Reply with quote
Sent via PM:
Well in response..
Iíve downloaded the zip file including .wav files
Unzipped the file and saved to desktops
Iím using the Garmin POI loader.app on Mac computer Followed all the steps .. and placed the POI onto a mem stick
I have in the downloaded file:
Poketgps_u...asto .. bmp files
Poketgps_Uk...Gaston.. cvs files
Poketgps_u.. wav.
I do not see any other .exe files.
File size 20.6 MB
Still not working.. Sad although I can select individual .wav files they play on my pc & Kenwood unit ..but no audio whilst in sat nav..
OK, the Mac version doesn't need sox.exe to add the audio files - that's a Windows thing.
When you run POI Loader at the end it should say how many POIs have been transferred.
Can you let us know how many?
Also, are you saying there are only 3 files in the zip download?!
PostPosted: Thu Nov 29, 2018 10:06 am    Post subject: Reply with quote
There are no .exe files in the download. That's why you can't find one.
Speedcat1
PostPosted: Sat Dec 01, 2018 6:30 am    Post subject: Reply with quote
Thanks for the help..itís now up and running... audio & visual Working fine...
Just one thing now... audio announcements very loud... how do I adjust the volume of the announcements?
PostPosted: Sat Dec 01, 2018 9:47 am    Post subject: Reply with quote
If there is no separate volume control then you will need to tweak the .wav files in something like Audacity.
Hopefully Audacity has a batch volume tweaker like my Adobe Audition or it can take some time..
Satnav:
cjay2412
PostPosted: Sat Dec 01, 2018 3:28 pm    Post subject: Reply with quote
on a dnx5240 dabs, I had to reduce the wav volume by 85% using audacity to get the volume to the same level as navigation newer kenwoods done require any adjustment at all.
PostPosted: Sat Dec 01, 2018 4:05 pm    Post subject: Reply with quote
Just to clarify. When you said reduce by 85%, did you mean that the resulting file was reduced in amplitude by 85% so that it is now only 15% of its original? Or did you mean 'reduced to 85%' of original. In this case it makes a lot of difference.
Sorry to be so pedantic, but lots of peeps screw up especially when they say stupid things like 'reduced by 10 times' instead of saying 'reduced to one tenth'.
PostPosted: Sat Dec 01, 2018 4:58 pm    Post subject: Reply with quote
So the advice here is keep the originals and work on a copy set.
Satnav:
PostPosted: Sat Dec 01, 2018 5:01 pm    Post subject: Reply with quote
You can always download another set when you have reduced the originals to 15% and can no longer hear them K. Rolling Eyes
cjay2412
PostPosted: Sat Dec 01, 2018 5:57 pm    Post subject: Reply with quote
I reduced it by 85% to 15%. unmodified it played at radio max volume reducing it to 15% it played at 15% of max radio volume. Poi warning volume is set at 100% of max radio output and cannot be changed. It is independent of satnav voice volume. So the only way to change the volume is to modify the file and see that you think of the new volume. It took a few tries until I got it to a level I liked. On newer kenwoods poi volume is linked to satnav voice with poi only marginally louder than voice directions.
PostPosted: Sat Dec 01, 2018 7:01 pm    Post subject: Reply with quote
Thanks for the clarification cjay
17.103 (16 Oct 19)
