M8TJT The Other Tired Old Man
Posted: Fri Dec 23, 2016 3:23 pm Post subject: |
You obviously didn't read the thread as this was posted, amonst others on the previous page to your last post that says you must leave the SD card in the car. wartklin wrote: | M8TJT wrote: | Ot might also be worth while emboldening the last para, as it seems that some people may not realise that you have to leave the SD in in the device. |
Yes it is important that you create a folder nameley "PerosnalPOI"as this is the only folder you should have on the SD card and the gpx files are loaded into this folder. |
I agree with Kremmen for you to have a go at getting the voices to work though. That would be a good result.  |
ticitybo Occasional Visitor
Posted: Fri Dec 23, 2016 3:28 pm Post subject: |
Oh, that sounds a bit more complicated and I've got no idea what SOX.exe is or what it does :-)
Will do a search during the Christmas break to see if I can figure this one out. |
Posted: Fri Dec 23, 2016 3:42 pm Post subject: |
SOX.exe is a small program that POILoader uses to convert .WAV files into something the Garmin can use.
There's loads of expertise here. If you are up for the challenge after the hol, then come back and I'm sure that Kremmen (the real expert) will hold your hand on how to do it. |
Kremmen Pocket GPS Verifier
Posted: Fri Dec 23, 2016 4:32 pm Post subject: |
All joking apart, getting the wav files to work with sox and into the gpi file is well worth the effort.
It's a one off file move into the POILoader folder once you have the sox.exe
It's the icing on the cake.
There are already loads of posts here with sox explanations including a few I've posted with pictures. _________________ Satnav:
Garmin DS61 LMT-D (Indoor test rig)
Garmin 2599 LMT-D (Indoor test rig 2)
Posted: Fri Dec 23, 2016 7:22 pm Post subject: |
@ticitybo
Can you set up proximity distances, or is it set by the device?
@Kremmen
The problem with posts about SOX.EXE is that there is so much chaff to sort the wheat from, just a few pearls of wisdom scattered amongst the dross including confusion as to which folder it should go in. |
Posted: Fri Dec 23, 2016 7:51 pm Post subject: |
My problem at the moment is that I'd like to include the existing graphic of the POILoader folder with the sox shown at the end, but, I'm away from the PC and trying to be clever on a phone is impossible.
Isn't there that Noddy guide somewhere ? _________________ Satnav:
Posted: Fri Dec 23, 2016 8:23 pm Post subject: |
Kremmen wrote: | Isn't there that Noddy guide somewhere ? | Yes, but it's not easy to find. I couldn't. I expect you wrote it K. |
Posted: Sat Dec 24, 2016 5:58 am Post subject: |
I did, and you named it at the time  _________________ Satnav:
c180081c Occasional Visitor
Posted: Sat Mar 11, 2017 9:48 pm Post subject: |
My COMAND works with the files fine however when I turn the car off it forgets and I have to reload, any tips? |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10640 Location: Suffolk, UK
Posted: Sat Mar 11, 2017 10:28 pm Post subject: |
Sorry to butt in.
Kremmen wrote: | Isn't there that Noddy guide somewhere ? | Did you mean This?
Or this:
 _________________ Richard
TT Via 135 App 12.075: Western Europe Map v1110 |
shinydoc Lifetime Member
Joined: Feb 28, 2009 Posts: 25 Location: Hampshire, UK
Posted: Mon Jun 12, 2017 6:34 pm Post subject: W213 Command NTG5E |
Hi All,
I have a new W213 E-Class with Command version NTG5E and cannot get any of these methods to work.
Some won't work as the options do not appear anyway.
Am I the only one with this problem, or has someone managed to get it to work on these variants?
I have really missed my PGPSW files, having a TomTom Go5000 too and there is no working solution for that either
I guess manufacturers just want to corner the market and continually rip us off.
Thanks |
Posted: Mon Jun 12, 2017 9:00 pm Post subject: Re: W213 Command NTG5E |
shinydoc wrote: | I guess manufacturers just want to corner the market and continually rip us off. | That sounds about right |
Si_23 Occasional Visitor
Posted: Mon Jun 12, 2017 9:13 pm Post subject: |
ticitybo wrote: | Ah ha. I’m sorted
Didn’t realise that with the system that is on the car I don’t need to import the speed camera data base and this is where I’ve been going wrong.
I simply copy the .gpi files (UK and EU) to the POI folder on the Garmin Map Pilot Europe 2016 SD Card and the system automatically reads the information and displays the camera as and when I approach one, it even plays a “bong” alert. |
I've come to the conclusion I'm downloading the wrong files (.GPX) instead of .gpi. What SatNav system did you select from the download option? |
Posted: Mon Jun 12, 2017 9:32 pm Post subject: |
Si_23 wrote: | ticitybo wrote: | Ah ha. I’m sorted
This is what I downloaded
Mercedes Comand [ UK - Single file with all cameras | pMobiles: Yes | French: No | Swiss: No ]
(15.061 - 07 Jun 17) |
Posted: Mon Jun 12, 2017 10:41 pm Post subject: |
shinydoc wrote: | Si_23 wrote: | ticitybo wrote: | Ah ha. I’m sorted
That is what I've just downloaded but it does not contain any .gpi files only .gpx. How did you get them to change to .gpi files? |
