Pocket GPS World :: View topic - Is Garmin still non-directional?
Goto page Previous  1, 2, 3
PostPosted: Thu May 09, 2013 3:29 pm    Post subject: Reply with quote
willmow wrote:
Audio Notification tab gives three radio buttons: Single Tone, Continuous Tone and Off.
That's the one's I meant Smile
Off - none
Single - one-off beep on approach
Continuous - keep beeping as you approach over speed
willmow wrote:
I've switched mine to Off, but still get all the bongs and pings. Crying or Very sad
Not sure why that would be the case... Maybe worth pestering Garmin as it may be a bug?
willmow
PostPosted: Thu May 09, 2013 4:54 pm    Post subject: Reply with quote
MaFt - could you check your end that the way the POIs are programmed by PGPSW aren't doing anything to disable the over-speed ping disabling (if you see what I mean!)? Garmin have told me that custom POIs "should" respond to the off/single tone buttons. They advised me to experiment with the Garmin POIs - if they work, then the problem lies with the custom POIs. Can't go out for a spin to check right now...
dales
PostPosted: Fri May 10, 2013 12:27 pm    Post subject: Reply with quote
Does not Ash10's thingy stop the repeated warnings?
Yes, Ash10 gives you one approach warning (say 30 seconds out) and one overspeed warning (say 15 seconds out).
For each camera type (mobile, gatso, redlight and specs) you can individually set the warning times and also choose whether the warnings will sound or not.
So, for example, you can have overspeed warnings for just gatso and redlight, and approach warnings for all camera types.
Dales
nuvi 2599LMT-D, oregon 700, basecamp, memory-map.
PostPosted: Fri May 10, 2013 2:59 pm    Post subject: Reply with quote
Than ks for helping me out on that one Dales. That's about what I thought it could do, but I haven't used it myself but knew that someone here has and could help out Very Happy
willmow
PostPosted: Fri May 10, 2013 3:20 pm    Post subject: Reply with quote
Well, I contacted Garmin. Here's my message to them and their ever-so nice reply. Rolling Eyes
I love my Zumo 660 but I wish Garmin would allow third-party
providers of POIs to access the "direction aware" capability of the
device. I am a user of the fantastic PGPSW service that provides weekly
updated information on traffic safety camera sites but the information
is not direction sensitive (in other words warnings are issued even if
the camera applies exclusively to the other lane of traffic). I am
informed that this is because the service is prevented from accessing
the full capability of Garmin satnavs. Could I encourage Garmin to allow
full access to the technology? You would make a lot of people very
happy.
From Garmin:
I have forwarded your email to the design team as they are always
interested in customer feedback. Many of the comments/suggestions we
receive (such as yours) are often evaluated towards potential
implementation into future Garmin products or current unit software
releases. We cannot guarantee that what you have suggested will be
implemented, however we do appreciate you passing along your opinions.
We also have a portal for customers to submit ideas directly to our
innovation experts. Please share your ideas with us at the following
page on our website: http://www.garmin.com/ideas
PostPosted: Sat May 11, 2013 1:23 pm    Post subject: Reply with quote
I'm not holding my breath Smile
Satnav:
carl_w
PostPosted: Mon May 27, 2013 11:09 pm    Post subject: Reply with quote
MaFt wrote:
Off - none
I am using the PGPSW .wav files and have mine set to "Single" but still get alerts when approaching over the speed limit.
This is particularly annoying in average speed camera roadworks zones, where I set the cruise control to 50mph on the GPS. As I assume there's a bit of drift either way, as soon as it goes a little bit over 50mph the alert sounds again.
I guess I could solve this by setting the cruise control at 49mph, but then I don't feel I'm making best use of the average speed restriction Smile
PostPosted: Tue May 28, 2013 7:01 am    Post subject: Reply with quote
If you use the utility WalkerX and I created you can turn off overspeed warnings by camera type and speed.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=91951
I think for specs camera areas I prefer to have it remind me though. It's also unusual for a car speedo to read less or the same as GPS.
If I set my CC to 60 (car) then the SatNav reads about 58 so I get no overspeed warnings.
Satnav:
carl_w
PostPosted: Tue May 28, 2013 1:12 pm    Post subject: Reply with quote
Yes but I set my CC to (say) 54 so that the GPS shows 50.
Does your utility make it possible to change the overspeed warnings, e.g. by only sounding them if you're travelling 10% over the posted limit?
PostPosted: Wed May 29, 2013 6:27 am    Post subject: Reply with quote
No, it uses the speed and separates them into approach and overspeed. The one main problem with Garmins is where you have cameras on opposite sides of the road (Motorway gantries for example). This causes double the warnings as they stack up. This has a knock on effect of still producing warnings when you have passed the camera.
I do cater for this and the warnings are considerably reduced.
Satnav:
Page 3 of 3
21.033 (15 Mar 23)
