Pocket GPS World :: View topic - Loss of signal
Loss of signal
Afuss
PostPosted: Mon Mar 04, 2013 3:08 pm    Post subject: Loss of signal Reply with quote
I was walking from the Kinder Scout plateau in Derbyshire towards Jacob's Ladder the other day and all of a sudden I lost all satellite connection. I thought it was because I was descending into a valley but after 5 or so minutes (and lower down) about 9 of the satellites returned. My partner suggested that there might have been some magnetic interference in the area (underground water). This seems a very plausible explanation. Any other ideas as to what might have happened?
PostPosted: Mon Mar 04, 2013 5:10 pm    Post subject: Reply with quote
I'd be very surprised if that was the case, but then I've been surprised before Wink
I tend to favour your idea that as you descended into the valley your GPS's view of the satellites was blocked for that time. Do you know the exact grid where it happened?
FrequentFlyer
PostPosted: Wed Mar 06, 2013 8:02 pm    Post subject: Reply with quote
I was up there the other week, and assuming the same route, had no problems.
Afuss
PostPosted: Thu Mar 07, 2013 2:33 pm    Post subject: Reply with quote
The route we took was up Crowden Clough to the plateau. Then along the plateau via Pym Chair towards what is called Swine's back. Just before reaching here we descended towards Jacob's Ladder. The route is well marked so we didn't deviate. There seemed to be a lot of sky showing so I was quite surprised when my A10 lost all signals and only regained them at a lower point were even less of the sky was visible!
PostPosted: Thu Mar 07, 2013 2:38 pm    Post subject: Reply with quote
Ah well bang goes that theory then as you're right, nothing on that route should give you a problem. Maybe just a glitch in the software? If it ever happens again try the standard fix ... switch off then switch on again Wink
Wombler
PostPosted: Mon Mar 11, 2013 8:20 am    Post subject: Reply with quote
Afuss, I don't know how old your unit is but suggest it may be due for a service which will include re aligning and tuning the antena's I was up in the Black Moutains the other week, lost all my satelittes on the top and never did get them back! I was well overdue for a service and it is currently with them. Yours might be on the way out if you lost them for no reason.
PostPosted: Mon Mar 11, 2013 12:57 pm    Post subject: Reply with quote
Crikey, never knew you could have a GPS 'serviced' Confused
Never needed that with any of my Garmins and suspect it's not really necessary for satmaps. When you get any significant glitches the best thing a user can try is a hard, or master, reset. That tends to cure the vast majority of problems.
WalkerDan
PostPosted: Wed Mar 13, 2013 6:44 pm    Post subject: Reply with quote
Just had my Satmap "serviced". All looks good to me. Had to dig the old Garmin 60CSx out while it was away but I reckon it needs a trip back to the manufacturers as well as not all the buttons functioning correctly. Pleased to see the Satmap back today with a decent size screen and OS maps, although there are some bits on the Garmin I prefer.
21.021 (01 Feb 23)
Terms & Privacy
