CA_0216224501 Lifetime Member
Posted: Sun Feb 03, 2013 12:48 pm Post subject: Similar but different |
GPS_fan wrote: | Unfortunately, bathbadger appears to be correct - CamerAlert is stable whilst static but crashes on the move.
6 crashes within 15 minutes this morning |
Iphone5 updated ioS 6.1 works fine then goes to standby mode but will work fine with no probs if I'm listening to an audio book whilst driving ??????? |
Darren Frequent Visitor
Posted: Sun Feb 03, 2013 1:18 pm Post subject: |
Do you have 'Prevent Standby' enabled in settings? _________________ Darren Griffin |
GPS_fan Pocket GPS Moderator
Joined: Jan 04, 2007 Posts: 2789 Location: Hampshire, UK
Posted: Sun Feb 03, 2013 1:44 pm Post subject: |
Yes _________________ Andy
PocketGPSWorld.com supports Help for Heroes - Read here |
Posted: Sun Feb 03, 2013 3:38 pm Post subject: |
Sorry Andy, that was intended for "CA_0216224501" in the previous post. _________________ Darren Griffin |
simont56 Occasional Visitor
Posted: Mon Feb 04, 2013 1:00 pm Post subject: Crash Logs |
MaFt wrote: | Crash logs do eventually filter back through to us via Apple but to speed things up can you locate them and send us them?
Can you send them to us at team AT pocketgpsworld.com
MaFt |
Am also suffering same problems.
Just checked my crash logs and it would appear that the crashes are listed as 'LowMemory' rather than CameraAlert. Not sure whether this helps.
Am running iPhone 4, updated with iOS 6.1, fully restored post upgrade and Camera Alert app deleted and re-installed with no change in performance.
Simon |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15137 Location: Bradford, West Yorkshire
Posted: Tue Feb 05, 2013 12:20 am Post subject: |
Thanks Simon. I was beginning to have my suspicions that it was a memory issue as the iPhone 4 is the oldest device with Retina screen that runs iOS 6.1...
MaFt |
Posted: Fri Feb 08, 2013 7:27 am Post subject: |
In map settings, if you change from 'Always' to 'Near Camera', it seems to improve stability.
Unfortunately, my journey is too short to thoroughly test, but CamerAlert did not quit at all this morning when it would otherwise have quit at least 5 times. _________________ Andy
Posted: Fri Feb 08, 2013 8:27 am Post subject: |
As it appears to be an issue caused by the vector maps gobbling up memory in 6.1, you may find that switching off the maps stops the crashing completely.
I know this isn't a long term solution but it might at least allow you to use the app, without it crashing, in the interim whilst we research a fix. _________________ Darren Griffin |
Posted: Fri Feb 08, 2013 8:36 am Post subject: |
...if maps are turned off completely, would you still get your average speed displayed in an average speed camera zone? _________________ Andy
Posted: Fri Feb 08, 2013 8:37 am Post subject: |
GPS_fan wrote: | ...if maps are turned off completely, would you still get your average speed displayed in an average speed camera zone? |
Yes _________________ Darren Griffin |
Posted: Fri Feb 08, 2013 10:28 am Post subject: |
GPS_fan wrote: | In map settings, if you change from 'Always' to 'Near Camera', it seems to improve stability. |
Which, again, goes hand in hand with the memory theory - if the maps are only being displayed for a short period (near a camera) then there is less map data being stored in memory and therefore the 'crash' will take longer to occur.
MaFt |
jdp1962 Occasional Visitor
Posted: Sun Feb 10, 2013 4:11 pm Post subject: |
I updated to iOS 6.1 this morning, and immediately encountered the problem with Camera Alert shutting down every two minutes or so. I'm just in the middle of a phone restore at present, then will try it with maps always on and with maps only on near camera, see how it behaves and report back. |
Posted: Mon Feb 11, 2013 9:49 am Post subject: |
Still shuttong down every couple of minutes. Will next try deleting the app, and reinstallnig it from scratch. |
Posted: Mon Feb 11, 2013 9:52 am Post subject: |
Try it with maps set to 'Never' - this has improved stability for me. _________________ Andy
lbendlin Pocket GPS Staff
Posted: Tue Feb 12, 2013 7:30 pm Post subject: |
Even with maps set to "Near camera" you can mitigate the issue for some time. I did some performance analysis with the Xcode tools ("Instruments") and there is definitely something broken with the vector map memory management. It is sufficient to pan and zoom the map around a bit to cause the app to silently terminate - without a crash log. Memory usage can go as high as 250 MB which is especially problematic on low spec devices like the iPhone 4 (not sure how much RAM it has but I seem to remember it was only 512 MB).
Looking in the Apple forums they are certainly aware of the issue but it doesn't look like a fix was included in the latest 6.1.1 version. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
