Pocket GPS World :: View topic - Need help with NAVMAN N189(F25)
Goto page Previous  1, 2
cristiron
PostPosted: Sun Jul 10, 2011 11:22 am    Post subject: How to Navman F25 N189 Cobia_250_32 COBIA250.V1.00.0002 Reply with quote
This is a model which I bought from Lidl in Germany in 2009 I think and contains West and Central Europe, has no card slot but 1 giga internal flash drive. Does not detect Active Sync unless you install MioPocket 4.0 and then will work. To install MioPocket, connect the device with an USB cable to your computer to have access to your flash drive of the device. If the computer does not detect the periferical then try to install TomTomHome to your computer for the drivers. Restart computer after then connect your navman. An icon Mio Device should appear in My computer. I use Win XP. Transfer files and folow instructions MioPocket 4.0 Readme.htm file: Copy directly to flash drive and rename as for Mio Moov/Spirit or Navman. Navigate to the directory of your device's original navigation application: \Program Files\Navman\SmartST_CE After instalation, do not delete MioAutoRun\System\CE4 or CE5 or other CE folders as indicated on help file as might be buggy for your miopocket.Mireo viaGPS 3.1 Black Edition works best. If your GPS is not detected by the soft, use GPS Utilities to select Switch to NMEA. Use 201006.cpf maps. On reboooting occasioanlly Launch. exe fatal error might appear, just do a hard reboot do to fix it. To boot the device, always disconnect from the computer and reconect when boot completed, for the power supply.If left connected during booting the device will comutate as a local drive for the PC and booting stops. To use Active Sync, in the device select Settings--USB Mode than select from the options
Page 2 of 2
22.043 (17 Apr 24)
