Pocket GPS World :: View topic - PGPSW Speed Camera Database on TomTom iPhone App
Goto page Previous  1, 2, 3 ... 13, 14, 15 ... 40, 41, 42  Next
mrstella
PostPosted: Fri Apr 15, 2011 7:08 pm    Post subject: Reply with quote
Hi All
Having a slight problem, i have copied everything over as per the original post but when i get to a cam i get all the warning alarms from the tomtom but the POI icons are just red squares.
any ideas
PostPosted: Fri Apr 15, 2011 7:14 pm    Post subject: Reply with quote
Use DiskAid to copy and replace the icons in your map folder with the ones in the zip download available on page one of this thread, there must be something wrong with the icons you installed the first time around - Mike
mrstella
PostPosted: Fri Apr 15, 2011 7:51 pm    Post subject: Reply with quote
just reinstalled and still happening
http://img828.imageshack.us/i/img0069.png
http://img801.imageshack.us/i/img0070r.png
any help would be great,
PostPosted: Fri Apr 15, 2011 8:11 pm    Post subject: Reply with quote
What version of the TomTom app have you got installed and which map version - Mike
mrstella
PostPosted: Fri Apr 15, 2011 8:18 pm    Post subject: Reply with quote
tomtom v1.4
app version 8.3 (538812)
UK and ROI V850.2821 map
PostPosted: Fri Apr 15, 2011 8:48 pm    Post subject: Reply with quote
Update it to the latest current release v1,6 as updates are free via iTunes, the version you have doesn't support the png custom POI files (it might work with bmp files but I have never tested this) - Mike
mrstella
PostPosted: Sat Apr 16, 2011 9:51 am    Post subject: Reply with quote
bmp files and its fine so all sorted...
thanks
PostPosted: Sat Apr 16, 2011 9:54 am    Post subject: Reply with quote
bmp files will work with v1,4 and earlier, for v1,5 and later releases the files need to be bmp with the file extension renamed to png - Mike
bobgentry
PostPosted: Tue Apr 26, 2011 3:00 pm    Post subject: tomtom 1.7 Reply with quote
I have just upgraded to tomtom 1.7 and have had to re install the camera database.
however I now get just red squares insted of the correct image.
I used the pngs from the download on the first page.
has something changed?
http://www.dees-fancydress.co.uk
A magical place full of wonderful fancy dress costumes.
PostPosted: Tue Apr 26, 2011 3:03 pm    Post subject: Re: tomtom 1.7 Reply with quote
It would appear so, when my iPhone has finished updating I will load the V1,7 released today and see if this latest little challange can be worked out, yours is about the fifth post I have seen so far on this issue - Mike
bobgentry
PostPosted: Tue Apr 26, 2011 4:01 pm    Post subject: Reply with quote
found the answer on another post.
you must use real 24 bit png's now
ArthurFuxake
PostPosted: Tue Apr 26, 2011 9:30 pm    Post subject: Reply with quote
Confirmed. I renamed all my *.png files back to *.bmp. I then used a free Windows program called IrfanView to batch convert them all to png files and ticked a box in IrfanView's advanced batch settings to convert to 24 bit (as I had a few that were only 8 bit). Uploaded them back to the iPhone and no more red squares when using v1.7
Steve
BaggieBoy
PostPosted: Tue Apr 26, 2011 10:11 pm    Post subject: Reply with quote
Updated to v1.7 and now seeing no speed camera icons. I used the 1.6 mapsettings.cfg file, I'm suspecting this isn't compatible with 1.7?
Edit: Forget that, I'd forgotten to copy over the ov2 files... now getting the red square icons. Will do the bmp to png conversion process.
PostPosted: Tue Apr 26, 2011 10:16 pm    Post subject: Reply with quote
The answer is a few posts further up this thread, you need to use 24 Bit png files post the V1,7, to make it easy to find the start point in the thread click Here and read down for the answer - Mike
BaggieBoy
PostPosted: Tue Apr 26, 2011 10:20 pm    Post subject: Reply with quote
The problem was that I'd forgotten to copy the ov2 files, so as far as TT was concerned the POIs didn't even exist.
Page 14 of 42
22.044 (24 Apr 24)
