Pocket GPS World :: View topic - Telmap 5 : 5.12.32 is available
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Telmap User Group
nycbbuser
PostPosted: Wed Oct 27, 2010 7:44 pm    Post subject: Telmap 5 : 5.12.32 is available Reply with quote
I just checked and saw that Telmap 5.12.32 is available for download now!
nobody911
PostPosted: Wed Oct 27, 2010 8:29 pm    Post subject: Reply with quote
Download and activated ok.
Are there any release notes, what is fixed or new about this release availible ?
GuyH
PostPosted: Sat Oct 30, 2010 9:49 am    Post subject: Reply with quote
I've found the backilight economy mode no longer works in this release on my 9700
Dr_No
PostPosted: Sun Oct 31, 2010 10:58 am    Post subject: Reply with quote
Finally got it installed on my 9700 after having difficulties with missing .cod error.
Now i am unable to change language.
Trying to change to German the device shows
- Downloading German..
- Synchronizing resources...
- Unsuccessful attempt to change language.
At this state it is not possible to leave the language dialogue, i can only quit the program.
Tried also to switch to French, same error.
Is anyone else able to reproduce this error?
nobody911
PostPosted: Sun Oct 31, 2010 12:03 pm    Post subject: Reply with quote
I also have german as default language.
installed fine for me.
Dont know, if it makes a differece what device/OS you use.
Mine: 9700/v5.0.0.938, Platform 5.1.0.177
Maybe, try to remove telmap and try installing again before trying to upgrade/downgrade the OS ?
another possibility:
I had difficulties downloading the Application itself: When I tried to use the BlackberryBrowser (which uses the BES connection through my enterprise server), the Download failed/did not start.
I then switched the default browser to the WiFi browser, and logged myself into a WiFi network.
Download then was ok.
But before trying this, I would recommend to delete telmap, make a restart and then again try the installation.
6foot6inches
PostPosted: Fri Nov 05, 2010 3:20 pm    Post subject: Reply with quote
How are you able to specify the version that you download?
I've been using this link within the Blackberry browser to download what I assumed was the latest version, but it's showing as 5.12.26.
If there is a later version, I'd like to try it to see if it solves the hanging problems with the version I'm using as detailed here, here, here, here etc.! Crying or Very sad
6foot6inches
PostPosted: Mon Nov 08, 2010 7:38 pm    Post subject: Reply with quote
Thinking about this further, as an alternative approach, is there any way of getting hold of the prior version (i.e. earlier than 5.12.26) which worked fine for me?
Thanks!
BlackBerry Bold 9000
GuyH
PostPosted: Tue Nov 09, 2010 10:16 am    Post subject: Reply with quote
Found a bug on the latest version with Bold 9700 OS6. In the settings I cant see which of the top 2 items is highlighted where you can chance the units of distance used etc.
6foot6inches
PostPosted: Tue Nov 09, 2010 1:16 pm    Post subject: Reply with quote
I've just tried Telmap again and, after synchronising resources for a couple of minutes, it's fired up fine so maybe the issue has been fixed behind the scenes by Telmap! Question
Hopefully it'll behave itself again now...
ridr
PostPosted: Tue Nov 09, 2010 7:20 pm    Post subject: Reply with quote
Very Happy mine also behaving...
kb7ypf
PostPosted: Tue Dec 14, 2010 9:30 pm    Post subject: Telmap 5.12.32 Reply with quote
Telmap 5.12.32 works good on my BB 9700 Bold. Installation was easy, but at the end the screen froze. I pulled the battery and to reboot the BB. After that the BB and Telmap 5.12.32 worked great. Just hope it stays that way.
Does anyone know if OS6 will be made official for BB 9700 Bold?
Thanks.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Telmap User Group All times are GMT + 1 Hour
22.043 (17 Apr 24)
