gajet Occasional Visitor
Posted: Fri Oct 08, 2010 12:33 pm Post subject: Re: Camera Alert Stops working. |
Darren wrote: | lonesome wrote: | Camera Alert stops working behind TOMTOM. It may work when first starting out and then nothing until I swop them around to restart. It isn't consistant and cannot be relied upon at the moment to work in the background. |
In what way does it stop working? |
I've seen this twice too. I've completed my journey and shut down Tomtom, and noticed the "GPS active" icon on the phones status bar dissapears with Tomtom. I touch the CamerAlert icon with the intention of terminating that app and it starts up, implying it was not working in the background.
I would expect when closing down Tomtom I would continue to see the GPS indicator as CamerAlert would be active.
However I need to play more to form any real conclusions. |
WindyMilly Occasional Visitor
Posted: Fri Oct 08, 2010 12:56 pm Post subject: Re: Bluetooth Sounds |
Darren wrote: | WindyMilly wrote: | Doesn't the Apple SDK allow apps to access Bluetooth? It would be so useful if CA broadcast sound over BT. |
If sound is being played, and your cradle support the use of BT Audio then that should work.
I'm not sure but I don't know if the iPhone supports BT Audio without the use of a compatible cradle though? |
Darren - thanks. Even though the iPhone is physically connected to the cradle for charging, the phone connects the BMW's iDrive via BT. I cannot play the iPhone's iPod with my set up. I have a separate iPod (nano) in the glovebox which also connects to iDrive and mimics a CD changer.
The solution I'm looking for would be for CA to broadcast its audio over BT to iDrive simulating a phone call. |
Darren Frequent Visitor
Posted: Fri Oct 08, 2010 12:59 pm Post subject: |
Ah I see. If you can't play iPod music over the BT connection you have then we cannot broadcast our sounds/alerts.
XCode gives no control over that, it's handled at the OS level. _________________ Darren Griffin |
lonesome Lifetime Member
Posted: Fri Oct 08, 2010 1:13 pm Post subject: |
Camera Alert stops announcing camera positions. For example this morning it anounced the first mobile position half a mile from start but nothing more for the next 50 miles until I swopped with TOMTOM
and back after it had found my location on the map then it worked close to my destination. I have just done a short 5 miles where it did work. Can TOMTOM "Poor GPS Reception" stop Camera Alert from working when the signal is again picked up? |
Posted: Fri Oct 08, 2010 1:29 pm Post subject: |
Darren wrote: | Ah I see. If you can't play iPod music over the BT connection you have then we cannot broadcast our sounds/alerts.
XCode gives no control over that, it's handled at the OS level. |
OK. BMW do offer a smart phone interface option which I believe allows the iPod to play through iDrive either directly connected or over BT. I'll have a word with my BMW stealer to see if I can get any sort of credit on the glovebox iPod/CD changer gizmo as this would then be redundant.
Thanks again for all your hard work. |
lbendlin Pocket GPS Staff
Posted: Fri Oct 08, 2010 2:33 pm Post subject: |
Keep in mind that BT Audio is not the same as BT Audio.
You need to differentiate between Handsfree/Headset Audio transmission (which is mono, and exclusively for phone conversations) and Music audio (also known as A2DP).
CamerAlert supports and detects the A2DP audio connection. (In that case we play some silence before and during the announcement, in order to keep the BT connection up, and to prevent choppy announcements).
There is no way to push announcements through Headset/Handsfree profiles. Whatever you have in your car has to support A2DP. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
wazzzzupmate Regular Visitor
Posted: Fri Oct 08, 2010 7:23 pm Post subject: |
I am running Tomtom on the iphone3gs in the Tomtom iphone cradle.
Since running both Tomtom and the pgpsworld speed cam app at the same time I keep getting a poor gps signal. So much so I have to close down the cam alert to get the Tomtom working ok.
Has anyone else noticed this? _________________ -------------------------
Tomtom Go 400
Tomtom 1.15.1 for Iphone |
GMT Occasional Visitor
Posted: Fri Oct 08, 2010 10:01 pm Post subject: |
I've tried using the new version with tomtom running and it seems to be conflicting with it .. With cameralert running in the background tomtom keeps losing gps signal every 5-10 seconds. As soon as I close cameralert down tomtom works perfectly again.
Using an iPhone 4 with latest versions of all software..
Any ideas ? |
Posted: Sat Oct 09, 2010 10:42 am Post subject: |
GMT wrote: | I've tried using the new version with tomtom running and it seems to be conflicting with it .. With cameralert running in the background tomtom keeps losing gps signal every 5-10 seconds. As soon as I close cameralert down tomtom works perfectly again.
Any ideas ? |
As I've said a few times in this thread, and as forewarned on the CamerAlert iTunes page, TomTom v1.4 has a bug that causes this.
It happens to some even when not using CamerAlert and is outside of our control.
TomTom have submitted v1.5 to Apple which fixes the bug, I have it here and can confirm that. We're just waiting on Apple to approve it and release. _________________ Darren Griffin |
Posted: Sat Oct 09, 2010 10:52 am Post subject: |
Thanks Darren. _________________ -------------------------
Tomtom Go 400
Posted: Sat Oct 09, 2010 10:56 am Post subject: |
Thanks, and sorry should have read the whole thread before posting!
Hope 1.5 comes out soon! |
Posted: Thu Oct 21, 2010 7:40 am Post subject: |
I have used camera alert with Tomtom 1.5 for the iphone this morning and driven about 60 miles. I can confirm that Tomtom no longer loses the gps signal when multitasking with camera alert. Early days yet but so far so good. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15126 Location: Bradford, West Yorkshire
Posted: Thu Oct 21, 2010 10:19 am Post subject: |
so it WAS TomTom after all like we said . Hopefully the AppStore reviewer will update TomTom and their review too after saying OUR app doesn't work with TomTom. Reality is/was that TomTom didn't work with our app
MaFt |
johngoodland Occasional Visitor
Posted: Thu Oct 21, 2010 10:51 am Post subject: |
MaFt wrote: | so it WAS TomTom after all like we said . Hopefully the AppStore reviewer will update TomTom and their review too after saying OUR app doesn't work with TomTom. Reality is/was that TomTom didn't work with our app
MaFt |
I will... but I need to to do further tests
Running Camera alert and Tomtom resulted in, as you said, the tomtom hardly dropped out. However, the camera alert through the road works at Cathorpe interchange didn't fire an average speed 50 alert (I have the latest DB and know these alerts fire)
No problems further up the road with the static 30. |
Posted: Fri Oct 22, 2010 8:05 am Post subject: |
Thumbs up from me guys
Spent the evening giving this version a good old bashing around m42,m6, m1 with tomtom and camera alert running without any issues.
Have reviewed this version and gave you the full marks |
