Pocket GPS World :: View topic - Cannot open an Ozi map on my PocketPC correctly
Valery
PostPosted: Mon Jul 26, 2004 11:08 pm    Post subject: Cannot open an Ozi map on my PocketPC correctly Reply with quote
Hi all,
I have an *.ozf file and a *.map file which open Ok on my PC, but when I try to open them in Ozi on my PocketPC it says that the Map Projection is not supported. I opened the *.map file and discovered that its projection is EQC (Equidistant connection). Can I recalibrate or convert the map somehow to use the Latitude/Longitude projection?
Thanx!
PostPosted: Thu Jul 29, 2004 6:41 pm    Post subject: Reply with quote
From the sounds of things you need to convert your .ozf file to a .ozf2 using the img2ozf2 program from the www.oziexplorer.com website.
Though this should use the .map file which is where the calibration comes from. It may be that the format of the ozf file is causing the problem.
22.043 (17 Apr 24)
