Pocket GPS World :: View topic - Navman F20 Internal Micro SD Card Structure.
johnmurphy
PostPosted: Sun May 09, 2010 4:07 pm    Post subject: Navman F20 Internal Micro SD Card Structure. Reply with quote
Hi to everyone here, I'm new here but need a bit of help.
I have an F20 which had a broken usb charger socket which I have now repaired.
When I took it apart my daughter wanted to borrow the internal
micro sd card for her phone for a short time.
I copied everything from the card to a folder on my pc.
When I'd finished the repair I copied everything back.
Now when I switch it on it says No Map Data Available.
Everything is still there including a folder with the map data in.
But I can't remember if all the folders in the Navman folder where on the root of the card or if the Navman folder was on the root with all the other folders inside it.
There is also 2 files called Version and Source, not sure where they go.
I need to know the structure of the folders on the memory card
in case I messed something up.
Any help would be greatly appreciated.
Thanks.
pan_peterpan
PostPosted: Tue May 18, 2010 9:21 pm    Post subject: Reply with quote
NAVMAN and source.txt must be in root all rest folders and files in NAVMAN everything seems to be ok
johnmurphy
PostPosted: Wed May 19, 2010 12:19 am    Post subject: Thanks. Reply with quote
Thanks for the help pan_peterpan but still have the same problem.
May be something else wrong with the device.
parkinson40
PostPosted: Fri Jul 02, 2010 2:09 pm    Post subject: f20 sd card Reply with quote
Sorry to butt in
I have two f20 navman.In changing the battery we flipped the sd car into the unknown(down the setee
Is it possible to straight copy the sd card from the survivor to a blank sd card?
We use windows xp.
thanks
CaptainDrift
PostPosted: Sat Jul 03, 2010 8:24 am    Post subject: Reply with quote
The files on the SD card are linked to that specific SD card ID. So no you cant copy the mapsand software to a backup card and use that.
You must have the original SD card from Navman inside the device.
22.034 (27 Mar 24)
